removing seats
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by VKCOMMO, Oct 10, 2009.
  1. VKCOMMO
    VKCOMMO Carpark Mechanic.....
    Springwood, NSW
    hey
    whats the process of removing all the seats in a vk sedan>>
    thanks
  2. NZVK308
    NZVK308 New Member
    south auckland
    VK sold.. VN3.8 and VX aclaim
    The rear back rest seats just pop out lift up then the bottom corners should pop out of the inserts.. the front seats use cap bolts to bolt seat to rails.. or just unbolt lock nuts from underside of the car and lift out..
  3. VKCOMMO
    Springwood, NSW
    thanks.. i was looking all over for bolts on the back seats.. su(so) just putt(pull) and it will come out
    things in brackets equals edits to show my bad spelling
  4. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    The back seat is easy..... once you know how to do it lol.
    The easiest, is put your hands in between the top and bottom half join crack, grab the bottom seat and pull it up. Once its up, you can move the front part of of the bracket. Then grab the vertical part and kinda pull it up, it will come off.
  5. VKCOMMO
    Springwood, NSW
    ok.. so you mean lift it up towards the rear screen/roof?? take off the arse or back part first??
  6. NZVK308
    NZVK308 New Member
    south auckland
    yup just pay to double check in the boot.. along the back bracing that it doesnt have a couple of retaining bolts holding the back seat rest in place... allso once you removed the top half.. check along the bottom of the bottom half on each corner there isnt a bolt in each clamp.. some have them some dont depends if the seats have been removed and replaced in a previous life..
  7. VKCOMMO
    Springwood, NSW
    ok.. thanks
  8. VKCOMMO
    Springwood, NSW
    but then again i like the look of the 68ish ones as well?? i cant decide
