Recommended place to re-grind 304 crank?
jimmyd17
Croydon, VIC
VY Adventra LS1
I'm half way through freshening up my 304. Pulled the crank and pistons out of the block yesterday, and checked the bearing clearances which were a bit out of spec as well as some looking pretty worn and marked. So I've decided I'll get the crankshaft reground, and new main & big end bearings. Pistons, rings and bores are all very good though.
Just looking for some advise as to where is a good workshop in the eastern suburbs of melb, to have the crankshaft re-ground as well as hot tanking the block and new cam bearings fitted.
thanks,
James
