quick connect fuel hose (in engine bay)
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by RWD4ever, Aug 24, 2019.
  1. RWD4ever
    RWD4ever Member
    Gosnells
    VS3 ute
    I replaced fuel pressure regulator. The quick connect hose would not come off, so I soaked it in hot water.
    It came off, but the fuel-resistant lining has detached - still stuck to the old regulator. So the hose is loose on the new regulator. I put a hose clamp on it, but I can still smell petrol sometimes.
    I presume those hoses (the return line that clips onto the pipe on the firewall) is no longer available. Is the quick connect fitting something standard that you might get from a performance shop or marine engine fitters?
  2. Pete O
    Pete O Member
    Meringandan
    1990 VG ute
    Check ebay, I have seen quick connect fuel connections on there, a few different types.
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    If your fuel pressure is leaking your going to have issues in engine performance.
    Did you pull the relay off your fuel pump while car was running to drain the lines to remove the pressure off the lines?
  4. RWD4ever
    RWD4ever Member
    Gosnells
    VS3 ute
    Rather hard to start, but ran fairly well when warmed up. Now better with new regulator.
    Didn't bother taking out the relay. When I loosened the old regulator, nothing spurted out - so the rail was already depressurised.
    losh1971 likes this.
