purge valve
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by gungazza, Jan 22, 2020.
  1. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    how do I get the hose of the back of the purge valve, looks like a fuel filter like conection ,my tools are to long to get in there
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    Just flick the tab with your fingers. Can't remember exactly where it is...
  3. gungazza
    west suburbs
    tried that no good
  4. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    Push all the way on, squeeze tabs and pull off?
  5. gungazza
    west suburbs
    ill try that, looks like both tabs need to be pushed in at the same time to hot to day, have to wait it it cools down theres got to be a way,i was looking at the other end of the pipe and that's looks just as hard ,,eny hose connectoions experts out there lol
  6. ant797
    ant797 Active Member
    bunbury
    vy s
    with my fuel filter i just push in hard then pull out use moderate force as might be stuck but not enough to brake anything
  7. gungazza
    west suburbs
    ill lt you all know how I go, doing cam chains, at the moment, o well getting there
  8. gungazza
    west suburbs
    still cant get the plug apart
  9. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    The front pipe, Push it toward the firewall and squeeze in the sides. Then pull back.
    Back one, Grrr, held in with a little latch against a small notch.
    Push the tab toward the back (toward the firewall) and then toward the engine. It took me heaps of goes to get that one.
  10. Wombat2020
    Wombat2020 New Member
    VE SSV
    Isnt there a tool that you slide inside the hose that tgen releases it?
  11. Fu Manchu
    WA
    VZ V6
    I got the one on the VZ and VE off with out it.
    I don’t think you’d get a quick connect tool in the space to release the connection.
    Wombat2020 likes this.
  12. greenacc
    VE Berlina
    Might be easier if you unbolt the valve first so you can lift it up enough to get a better grip.
  13. gungazza
    west suburbs
    valve is unbolted but I cant get it apart
  14. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Push the hose towards the purge body first wile hanging onto it, then squeeze the clips in then should pull out, if you have too use pliers to squeeze, if still wont come then repeat with twisting and wiggling side to side motion it will come.. Try push and pull in a fast motion.
  15. gungazza
    west suburbs
    the clips don't squeeze in thay are part of the valve. looks like you squeeze the hose but that don't work eather
  16. greenacc
    VE Berlina
    Do you have a new valve to look at? Should be easy to figure out by looking at a new one
  17. Fu Manchu
    WA
    VZ V6
    No. You need to see the end section of the hose to make sense of it.
    I’ll draw a picture tonight when I get home.
  18. Fu Manchu
    WA
    VZ V6
    This is a crap diagram. Bottom points to front of car. Top points to windscreen.
    Arrows indicate direction of movement.
  19. Trevor loves holden.
    vs commodore
    Is it this connector? there is two ribs either side on the clip just push hose in and then push in ribs and then pull back and hose will come off, may take a little bit if its been damaged according to 07GTS.
  20. Trevor loves holden.
    vs commodore
    delete
