Post your car audio system and pictures
Yande
South Coast NSW
VX Acclaim Wagon
Searched everywhere.. Looking for a definitive answer. Half installs here have 6.5" and other half have 6" speakers in the front doors. Will 6.5" fit VX Series II front doors without too much modification?
Nic92
WA
www.youtube.com
2005 Mitsubishi Evolution 9
Some fit depending on the size. They might need custom mounts, some will fit if you mod the plastic mount to fit the larger speaker. 6" fits perfectly without modifications.
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
Just to add to that... many 6.5” speakers are imposters!!!!
Well, sort of. They are listed as being a 6.5” but are in fact a 6” but have mounting tabs for a 6.5”.
Easiest way to tell is to look at the speakers mounting holes. A TRUE 6.5” will only have 4 screw holes whereas a 6” will have a lot more for different mounting options.
I don’t recall any true 6.5” being a drop in replacement. They’ve all needed the white plastic adaptor to be modified to some extent. Sometimes, I’ve just needed to cut off the water bucket and others have required me to run the jigsaw around the mounting plate to make it fit.
MrVR263
41
knox
VR commodore ute
VR UTE running a/d/s 346cs 6.5" 150rms splits up front with sound deadened inner and outer door skin/frame with acoustic speaker ring kit. Sound deadened floor, back panel and roof so everywhere you can put it pretty much. 2 x Rockford fosgate 10" P3s 300rms in Rockford sealed boxes and 2 Rockford punch 150 75rms x 2 @4ohm 25 to life amps with remote sub controller for subs amp.
