Post cat o2 sensors
WhiteSv6Ute
Mackay, Queensland
Ve sidi Sv6 Ute
Hey guys does any one know how a sv6 sidi will react to not having the rear post cat o2 sensors connected changed my exhaust and need new sensors but have to wait a couple of days for them to get to me, I'm guessing it will just run rich or lean. Any help would be great :)
commodore665
expat Saffa
51
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
May throw some codes , probably run a tad on the rich side as well .
PRAVX II S
Australia
Commodore
Hey mate how are you.
The post 02 sensor tells the ECM if the catalytic converter are working efficiently. Check engine light should come up right now with no sensors.
Are you using the factory catalytic converter or some high flow cats?
Reason i ask is because if you have high flow cats and you install the new Sensors this will still set the Check engine light on.
johnni
Ve Commodore
Hey guys :)
I just thought about something and wanted to get some feedback, Will changing all your o2 sensors in the ve make it a bit more fuel efficient ? Even tho theres no fault codes coming up but can new 02 sensors be much better ?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Will only throw the inefficient cat code.
New sensors will make a small difference, not really worth it until they **** themselves. But if your car has done more than 150ks then I'd replace them anyway.
