Piston slap LS3 - this is very interesting
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Ron Burgundy, Jan 21, 2020.
  1. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
  2. mpower
    mpower Well-Known Member
    yeah read this one yesterday too, just shows if you stick to your guns consumer advocacy groups can get you warranty.
    never be afraid to push back people - works for more than just cars!
    426Cuda, Ron Burgundy and panhead like this.
  3. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Not a bad purchase price for a newly released Series 2 Redline. $47,995
  4. Banjo79
    Banjo79 Active Member
    VF SS Sportwagon
    "Value Motors’ expert at the hearing, automotive engineer Karl Pemberton, said piston slap on this type of engine was “extremely common” and there was no evidence of mechanical failure."
    "on this type of engine" Wish he elaborated on exactly what makes an LS3 bottom end so far removed from many other internal combustion engines.
    "extremely common" With that choice of words, he's probably already flipping burgers. Can of worms has been opened. Should the engine have slap when cold or not? It can't be both.
    "no evidence of mechanical failure" True, just possible accelerated wear, but why mention that!
    I think if there was a new model to go to, Holden would have a lot of people like Mr Wilson pushing for the same thing and not only for piston slap.
  5. Ron Burgundy
    NSW
    VF II SS
    As most people here know Holden replaced my engine after 35000km due to really bad piston slap.
    The new motor has now done 7000km and I am starting to hear it again. Nowhere near as bad as the first time but still audible....Most people would not notice it..
    I do think that most engines have this but level varies based on internal tollerances...
    Pure chance really...which pistons will join which block on the assembly line...
    Pablito and Milo 6.0 like this.
  6. Milo 6.0
    Milo 6.0 Active Member
    perth
    2013 vf ssv wagon/bf xr6 na(daily)
    Saw this yesterday,just because piston slap is common it doesnt mean its acceptable,bloody holden....almost like saying yeah we know the motors are rubbish but theres so many knocking ls3s its classed as normal.
    Im glad i didnt hold out for an ls3.....that little bit of extra power isnt worth the grief of owning one!
    VF Redline likes this.
  7. Milo 6.0
    perth
    If i were you Ron id be speaking to a lawyer and going the same way as the guy in nz.
  8. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    It's sad to think that there are going to be a lot of VFII's in wrecking yards with stuffed motors in a few years. GM is doing their best to kill the Legacy of Holden/Commodore.
    Rather than a replacement motor it may be better to push for a rebuilt unit, one with proper piston to bore clearances because you really don't know what you are getting with another GM crate motor.
  9. Voodoo_SV6
    Voodoo_SV6 Active Member
    MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
    I wonder how many days later before the car was on a dealers lot somewhere up for sale to some other unsuspecting buyer?
    wetwork65 and VS 5.0 like this.
  10. panhead
    NSW Central Coast
    Cars
    I'd pointed this out before, a rebuild by a reputable engine builder is the better option for the customer plus you get to keep your original engine number which can mean much at resale for those who intend to keep the car for a long time.
    To swap in a new engine is the cheaper option for Holden but it doesn't necessarily mean the customer gets a better engine plus the you now own a non-matching number car.
    If it happened to my car I'd be willing to pay the extra cost for the rebuild over the cost of the installation of the crate engine.
  11. Milo 6.0
    perth
    Anybody heard if the lsa motors have the same issue?
    Is it the same 6.2 long motor?
  12. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Is the piston slap solely attributed to poor tolerance or is it also due to piston design with shortened skirts? From what I recall, pistons with abbreviated skirts for weight and friction reduction were prone to piston slap even when well with specified tolerance.
  13. Ron Burgundy
    NSW
    VF II SS
    Both.....
  14. revster
    revster Active Member
    30th Anniversary HSV Senator (Gone) MY19 Golf R
    Many differences between an LSA and LS3. Google will help.
    For example "Both LS9 and LSA are 6.2L engines biased on the LS3. Before you think that these motors just have a supercharger slapped on – you’d be dead wrong.
    Both are built to be 20% stronger than the LS3 short-block, according to GM, and even have forged (LS9) or hypereutectic pistons (LSA) with oil-spray cooling to handle the pushing power. The heads on these engines are similar to the L98/L76/LS3 heads except that they were slightly redesigned to aid in mix the air/fuel being pumped in by the supercharger."
    426Cuda and Milo 6.0 like this.
  15. wetwork65
    wetwork65 A wet business
    VF SSV Wagon & VF SV6 Wagon
    Exactly my thoughts Voodoo.
    And the price may be higher next time to offset their expenses in getting "automotive engineer Karl Pemberton" to carry out a rebuttal report.
    Ron Burgundy likes this.
  16. immortality
    Sth Auck, NZ
    Both but the newer pistons are made from better material that expands less with heat so "should" run tighter piston to bore clearances. Shorter skirts are definitely prone to more slap!
  17. VS 5.0
    Still talking about engines right ?
  18. immortality
    Sth Auck, NZ
    Sure ;)
    VS 5.0 likes this.
  19. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    I hope I never have to deal with this issue. I feel for those that have. I never had it in my new VY SS LS1, my new VF Redline, L77 (now 90k km's) or my Motorsport (9k km'), nor did any of my Son's 3 x LS1's, his L77 or his (current) LS3 with 200,000 k's on it and still going very strong. That said, I'm also mindful of the benefits of lightweight pistons, with short short skirts and less pin offset. More power, free revving amd better fuel economy. It's why most modern engines use such piston design. It's also true that piston slap is an inherent characteristic of this design. It's not just a GM LS characteristic. Skirts were there for a reason. Couple that with alloy blocks and heads and an increased risk of hearing a bit of cold slap is certainly there. If it's present when warm, that's not a good thing. Personally I wouldn't settle for it hot or cold. But, in a cold engine, I don't beleive it's an indication that the engine will self destruct.
    I remember my 360 Mopar back in the day with forged pistons, which used to slap it's head off when cold. The solid cam and lifters were noisy as hell too. Despite a very chuncky cast block. But, it revved to 7,500 easliy and never missed a beat.
    For me its a case of monitoring the Motorsport for any signs of slap. If it happens I'll be pushing Holden for a rebuild. But, I'm not going to lose any sleep over it.
  20. Holden17
    Holden17 Well-Known Member
    NthBris
    MY16 SV6 ute/MY17 LMF SS wagon
    Obviously got yours running ...:p
    VS 5.0 likes this.
