P0717 code
pierre hanna
51
kellyville
holden commodore berlina 1999 model
Got this code 0717 on my ve Commodore v6 omega duel fuel 2008model I replaced the part and still have that problem with the engine light is on and same code even after delete.
mechanic
Australia
Commodore
What part did you replace?
Did you do any tests or just throw parts at it?
pierre hanna
51
kellyville
I plugged an ob2 scan tool in and it told me the code. I deleted the code a few times and it kept coming up with the same code. When I erase the code and drive it it's fine and light doesn't come on .then after I switch car off and then restart and drive again the engine light is on. I replaced what I thought was the sensor on the back off the gearbox but now I'm not sure if it was the right one.
mechanic
Australia
Commodore
Ok cool. Need more info to help more.
Which sensor did you think you replaced? What did it look like, and why did you replace it?
Trevor loves holden.
vs commodore
Your transmission speed signal input is missing, maybe a wire connection problem symtons can trigger that code are as follows:
  • A faulty valve body
  • A faulty input/turbine speed sensor
  • One or more faulty shift solenoids
  • A shorted, open, or otherwise damaged circuit
  • Contaminated transmission fluid
  • A faulty engine coolant temperature sensor
you shouldn't drive to much to avoid damage to your transmission.
losh1971
North Tas
VR Ute V6
Find that on Google? I read something similar on the first page.
pierre hanna
51
kellyville
I replaced the one on the rear of the gearbox but reading other comments I think it's behind the torque converter in the front of the box . I am very confused.
vs commodore
Sounds like you replaced the output speed sensor, have a look towards bow housing if its not on the side it maybe up top, I'm not up to these current cars I'm more old school so I cant say for sure, someone else maybe able to confirm it, unless you can get a workshop manual.
