Oil problems
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Ronnie Sultana, Jan 14, 2020.
  1. Ronnie Sultana
    Ronnie Sultana New Member
    Tweed Heads NSW
    2005 VZ Commodore Ute
    Changed oil and filter now no light on dash
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    Not sure what the problem is. Is the light on or off?
    Which light is on?
    How much oil did you pour into the engine?
  3. Ronnie Sultana
    Tweed Heads NSW
    About 6 litres oil light was working before oil and filter change
  4. greenacc
    VE Berlina
    Oil light should only light up for 1 second when you start the engine. If it stays on longer than that it's a bad sign and indicates low oil pressure. So your fresh oil probably solved the problem you had and now you don't see the light..
  5. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    so how long or how many ks did you drive it with the light on
  6. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    Still waiting on answer of about question????????
  7. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    If you want the light back on then drain 3L of oil. lol...
  8. Ronnie Sultana
    Tweed Heads NSW
    Haven’t driven it at all
  9. ant797
    ant797 Active Member
    bunbury
    vy s
    The oil light is activated by the oil switch sensor as long as there is enough oil in there it wont stay on even if you havnt driven it
  10. Ronnie Sultana
    Tweed Heads NSW
    But it should come on before you start the engine
  11. stick3
    newcastle nsw
    yes all the warning lights do they only stay on if there is a problem
  12. ant797
    bunbury
    vy s
    If the light doesnt come on in accesories along with the others then you have a blown globe most likely
  13. ant797
    bunbury
    vy s
    On the vy there is no oil light check oil comes up on display might be the same for vz
  14. Trevor loves holden.
    vs commodore
    Did you spill oil on the senor below the filter when you changed it? Un-clip it give it a clean and see if it comes on.
  15. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Still haven't said which light isn't coming on.
    We have assumed it's an oil light.
    More info is needed from OP.
    How about a photo OP?
