No signal to iac valve
Discussion in 'Electrical Wiring / Questions' started by Lando, Oct 21, 2018.
  1. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    have just converted my vs clubby to manual and have a 355 stroker in it with a manual loom and computer from a vn ss . It has a high idle and I’ve found there is no signal or power to my iac valve. Probed at both the connector and pcm. Any idea what to check next ??? Or what powers those wires? Cheers
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    What intake mani you use? Any need to mod wiring?
    Did IAC work previously or is it new since the swap?
  3. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    One pair makes it step in the other pair make it step out .do you have both constant 12v feeds to the eco and the pink switched 12v and both earths from the engine loom attached on the engine in separate places
  4. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    I’ll check the power supply tomorrow. I thought that seeing as though the car runs that it would have to have power to the ecu
  5. delcowizzid
    NZ
    в∞ѕтεכ √&
    Do you have a check engine light thats working .if it's in limp home mode the iac might not work
  6. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    I have both constant power feeds and the ignition power. Engine isn’t in limp home as it drives fine just high idle
  7. delcowizzid
    NZ
    в∞ѕтεכ √&
    Obviously a custom tune in it
  8. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    What makes you say it’s a custom tune? Wouldn’t the 2 signal wires to the iac have power when operating the valve. ? Perhaps a dodgy loom?
  9. delcowizzid
    NZ
    в∞ѕтεכ √&
    355 stroker won't run to well on a stock vn ecu
  10. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    Yes I know it’s been tuned but that doesn’t explain why there is no power to the iac or do tuners sometimes turn that off
  11. delcowizzid
    NZ
    в∞ѕтεכ √&
    Was the tune made for the 808 vn ecu or did you swap it out of your auto ecu
  12. Lando
    Lando New Member
    Port Lincoln
    Vs clubsport
    Engine came with wiring loom and the ecu already tuned. Thinking I might just get a haltech ecu or another type of after market computer so it can be tuned properly as in south Australia its to hard to find a tuner that does the original computers
