Need a new shed
losh1971
North Tas
VR Ute V6
I'd be more comfortable with 600, especially under that plywood in the first pic.
900 centres is what is trusses are normally designed on in recent years and are worked out on the long span to how they are made. No need for 600 if the trusses have been engineered properly. 1200 centres might be a bit far, but engineering standards might be different in NZ.
VS 5.0
Engineering for roof support is different to supporting a load on those storage "platforms".
My concern is lack of support for the platforms that could sag with weight on them.
I'm sure @Deuce doesn't wanting something crashing down on either him, his family or his vehicles.
Nitro_X
Numbskull
North Queensland
2007 VE SV6
I need a new shed too, but haven't got the space....damn it.
I'd love a big ass shed....with a chill out section for bar fridge, pool table, dart board (with a piccy of ScoMo's face on it),
TV (for Bathurst weekend, the Superbikes and Sci-Fi movies)
:D
keith reed
73
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
After cyclone Tracey Australia adopted the NZ standard except that they added in provisions for cyclones that don't happen in NZ. Houses in NZ do not have a rod that goes from the top plate to beneath the bottom plate
Trusses are designed with a load rating. Last time I had anything to do with trusses they were for a house. They were spaced at 900 mm centres and made of 100 x 50 pine. Obviously as the load increases so does the size of the timber and the bracing of the truss.
Deuce
Super Stock
'94 VR SS V8
My shed is only 4 years old.
Now that I am getting a bit more organised and comfortable with the garage, an extra metre of width would make it more comfortable (up to 7m from current 6m).
9m depth with big work bench and storage at the far end seems really good and workable.
On another note, hanging things to keep the floor as tidy as possible:
MasterOfReality
Miners go deeper
41
All over
2019 LC Sahara TTDV8, 1991 VP Calais V8
Have collated some specs after a quick session of looking at various brochures and basic spec plans. This table prob won't be 100% accurate as i rushed it but gives a good idea of how they compare to each other. Prices are not including delivery to either house or depot. When it comes to it, I'll probably use a car trailer to pick up at depot, then unbox it on the trailer at home and move it with a few mates.
The BendPak looks the goods so far due to its narrow width. Needs a compressor though to disengage the safety locks. Have contacted them for pricing and to see if there is a 3 phase option on the motor. Hero Hoists and Tufflift also look the goods.
Meanwhile still chasing up shed builders, fark me its atrocious how some of them run their business.
Spec
Autolift AL-10000T
Tufflift TLV3.6PH-S
JGG JGG-4PSTSTD
BendPak HD-7P
Hero Hoists Lift King 9
HAPP HAPP25
Height overall (mm)
223720702230254022372318
Width overall without motor (mm)
27152629253426302845
Width between columns (mm)
235021082717229223992515
Length overall (without ramps) (mm)
438544584405442044604825
Lifting Height (mm)
130 - 19501842140 - 1900219718002000
Lifting capacity (kg)
350036294000317540004000
Power
240V/1Ph240V/1Ph240V/1Ph220V/1Ph220-240V/1Ph or 380-415V/3Ph240V/1Ph or 415/3Ph
Gross weight (kg)
765760785795
Price (inc GST)
387534903100Awaiting price36003900
VS_Pete
Donating Member
Sweet.
Good to see you have a chair.
Long walk one end to the other.:D
