My Vs SS Commodore 95 build
Discussion in 'VR - VS' started by Jarrid, May 3, 2012.
  1. VS_Pete
    Red and Black love them.
  2. Adelaidetradie86
    Adelaidetradie86 New Member
    VS Ute Series 2
    She a ripper looking ride. Those rims look really nice on your car. Im thinking about either them or a set of vy sigs. I reckon the vy sigs get a little too much attention from the boys on blue.
    Leaning towards your rims. Looks classy but still tough
  3. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    So after years of owning this car and complaining about my less than satisfactory clutch I finally have had the funds to order a new clutch and while I'm at it a rebuild on the T5 is on the cards. For anyone who's followed this thread you may have noticed me mention that this has been something I've wanted to do for a while (years) so stay posted for more photos and updates.
  4. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    21081983_1828319517184778_374539832_o.jpg 21081488_1828319577184772_719155602_o.jpg
  5. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    Thats how my garage currently looks.
  6. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    21057360_1828319400518123_1184419896_o.jpg 21057360_1828319400518123_1184419896_o.jpg 21081504_1828319480518115_386146010_o.jpg Dirty box.
  7. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    Nice and clean box 21081848_1828319487184781_84294245_o.jpg 21103711_1828319633851433_1666619694_o.jpg
  8. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    And finally old clutch out..... Cant quite put my finger on why the old clutch was slipping so much hhmmmmmmm...... 21081583_1828319733851423_1481340221_o.jpg 21081799_1828319460518117_234902455_o.jpg 21082101_1828319610518102_590115534_o.jpg 21104143_1828319553851441_667362096_o.jpg
  9. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    After taking my gearbox in to our local re-builder I got terrible news back.
    Most of my gears are marked or have small chips and aren't suitable for a re-build, he said he could put a new kit through it but it would still make noise and wouldn't be what I was expecting. I didn't think it was noisy before only in third at higher revs but I'm no gearbox re-builder so for now its bye bye to the old box as I've sourced a change over unit that's ready to go this Thursday so ill take a trip down to Melbourne in to the eastern suburbs to Statewide gearbox services it comes at a hefty price though he has told me he purchased these years ago from an old guy who pulled them out when they first came out and all they have done is put a new bearing kit in so should have done minimal work fingers crossed.
  10. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
  11. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    FINNNAAAALLLYYYY!!!!!! BACK DRIVING!!!!!!
    So after 2 and a half months what started out as a new clutch and a Gearbox freshen up turned in to fixing the rear main seal, new Cam and new brake master cylinder and a bit of paint on the God damn drivers side engine bay.
    So after removing the gearbox I started to notice tiny drips at the rear of the motor and I knew straight away what it was as the motor was tipped back letting all the oil sit right at the seal and eventually after a week or so it was a small patch sucked in to the concrete so I had the lovely job of removing the motor which was okay as a few things were already out of the way and I basically just had to disconnect everything and lift it out I labelled 90% of the plugs I removed so when it came back to reassembling I knew where it would go.
    After removing the motor it was headed for the mechanics whom happened to be our neighbors father, while I was there we were having a yarn and he said was there any tappet noise when the motor was running I told him it did he said my cam would be knackered and now was the perfect time to replace it, he had some NOS Wade Cams he had bought before they closed he said its nothing crazy but it will be perfect for me(little more poky but not big enough to need a re-tune) so after a minute or two I said alright do it so he sent it off to check if it was what he thought it was (hes a Crow cam rep or something along those lines) After a few days I got the Motor back new Cam and all the bits that go with it most of the gaskets, new Rear main and he showed me a few parts that needed replacing also (Water pump, rotor button, Dizzy cap) replaced all those, cleaned it all down of the 20 years of gunk build up while it was still out and painted the sump.
  12. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    While the motor was out it also showed another problem for me to fix my Master cylinder had a leak and it had eaten a lot of paint from the booster down to the the rail FML! after removing the booster, master cylinder and ABS module (all jobs I had always been afraid of doing but after I had done it the brake system is not that complicated) I had ALOT of masking and shitty hand rubbing to do in awkward spots but after a couple of days with me old boys help again there was fresh paint on, nothing special but at least it wasn't going to rust now plus most of that side you cant see/
    That was about the last job before Reassembly after talking it over I decided the easiest way to put it back in was to drop the K frame and reassemble as much as possible on the ground that way the clutch and box would line up nicer and no struggle getting top bell housing bolts, then pick the body up as high as we could, slide the motor box under, drop the body then lift and secure it in. The hardest part was positioning it under the car and lifting the body that high was all really sketchy but we got it done. Silly me forgot that when you get it a certain height back in to plug the Hall effect sensor in was a prick to plug it in when its back in Grrrrr, I did manage to put most of it back together but a few plugs stumped me and just how the loom runs around the motor. Picked up a cheap alloy Radiator one bloke at dads work ordered it but it didn't fit his v6 so dropped that in but held on to my original one just in case. bleed all the brakes with an air compressor bleeder tool all fresh fluid, filled the box, power steering and motor then gave her a few turns with the coil off then put it back on and no problems fired straight away! ran the Cam in and have taken it for a couple short drives the synchros are definitely working now and feels very tight selecting gears is better but I feel they could go in smoother. only thing stopping me fully having it together is the way the shifter mounts to the box, its different to my original one and the new inner boot looks like it will stretch to get over it? waiting for the weekend to see it i can fix it so I can reassemble the interior and start cruising in this good weather!
  13. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    TLDR Fixed clutch, replaced gearbox, fixed rear main, got new Cam,replaced Master cylinder, tidied the bay SUUPER excited for summer!!!
    Photos to come everything's a bit messy at the moment.
    PS F### hose clamps had 3 keep jumping a turn and not sealing hoses......
  14. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
  15. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    Couldn't help myself lol new member of the family in there as well Little Dakota
  16. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Awesome updates mate. Car is looking great.
    Congrats on little dakota too. :)
    Jarrid likes this.
  17. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    Thanks mate, been annoying me having everything apart and paying rego and its just sitting in pieces so I'm just that excited that its moving and its drive abillity is so much better now.
  18. Deuce
    Deuce Super Stock
    '94 VR SS V8
    The good thing about NZ is you can put rego on hold for 3+ months. It's good for bigger projects and stops me rushing to get it back on the road. Plus saves dollars.
    No transport issue when owning multiple vehicles too.
  19. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    NZ sounds good here its just about how much money they can squeeze from you.
    Just finished putting the Interior back together changed the AC unit out as 2 of the lights were blown and fit my inner boot, few things left to sort out inside like a rattle in the drivers door and the check strap pin creaks, rear drivers door lock is sticky and the passenger rear door handle plays up but one of the most annoying things is my dash lights wont stay on the full brightness it always stays dim so have to swap the fascia out as I've heard its like impossible to remove the light switch from it without breaking it. also sad news I lost another tab from my manual surround F###### why are they so fragile.....
    After another drive today and giving that right pedal a good stomp I now know the steering needs aligning as the wheel shakes like Micheal J Fox at 100 but its all coming together and I'm pretty happy.
  20. Jarrid
    Jarrid Member
    Ballarat
    Vs SS Commodore 95
    23313295_1901762973173765_27787817_o.jpg 23313085_1901762979840431_1186092632_o.jpg
    Deuce likes this.
