My only key for my ve Commodore sv6 has been stolen, what's my best cheapest option
Pauli1sv6
45
Newcastle
VESV6
You just need an active Key, and you program in an additional one.
Where a key [existing] will classed as a Master Key.
That's were it get a bit tricky I found, but still worked ok.
What if I haven't got a key at all
immortality
Staff member
Sth Auck, NZ
**** its 3am and I'm seeing double. Gotta stop doing these bloody night shifts...
krusing
Melbourne Bayside 3193
As you asked What If I haven't got a Key at all,
My only suggestion is to -
  1. Use a Mobile Locksmith,
  2. As mentioned, If you have the original Security Card that came with the car, you can get a Key ordered to Code, as a reputable Locksmith will be able to Supply & Cut the Key, and program it in to your Car, but he will need to Delete all the existing ones in there first.
losh1971
North Tas
VR Ute V6
If you take your rego papers to the stealer they can sell you a key. They will send the code to the locksmith and the locksmith will cut a key using the code. This is assuming the state you live in is like Tas where the only way a stealer will hand over the key cutting code is if you buy the blank off them.
krusing
That will cost you an Arm and a Leg, hence the name "Stealer"
On the other hand, If you have a mechanic mate/friend, they may be able to source it from you.
[for the cost of a small [liquid] token of appreciation ;) ]
stick3
newcastle nsw
vz sedan vs ute gsx1400
not that bloody hard to find a locksmith with a moblie service here in newy or we have two holden dealerships unless he/she is up to no good
