My 6.8L VT Clubby
Discussion in 'VT - VX - VU - WH - V2' started by JakeysVT, Nov 4, 2013.
  1. JakeysVT
    JakeysVT New Member
    '99 VT Clubsport R8
    My Clubby has come a long way since i first bought it as a bog stocker 5.7L with its catback but it now has :
    Engine : 6.8L Stroker Engine with manley 408 crank and oversize pistons 11.0:1 Compression Ratio
    1.81 ration Howards Roller Rockers, Hardened Pushrods, Howards TieBar Lifters,
    MAHLE Flat Top Pistons, Manley ConRods, High Volume Oil Pump, Ported Heads,
    Howrads 232/236 Cam, FelPro Gaskets.
    Clutch : XTREME Ceramic Cusion Button Clutch
    Exhaust 1 3/4 Stainless Steel Extractors, 2.5" Manta S/Thru Catback
    Suspension : SSL Fronts with Koni Shocks and King Springs, SL Rears With Koni Shocks
    and Nolathane Bushes All Round
    Diff : 3.9 Ratio TruTrac
    Gearbox : T56
    Power : Currently 421.5rwhp with 774.5nm of torque, with more to come :)
    Cheers for having a Look :)
    View attachment 167405 View attachment 167406 View attachment 167407
  2. kangavxss
    kangavxss New Member
    2002 VX SS
    Very nice beast you have there (its all legal im sure..hahaha)
    Noticed, or it looks like your otr rubs on your hood lining. I had the same problem (same otr) so bent the ac condensor in a gentle arc towards the radiator which allowed the otr to clear it and sit down more
    on top of the radiator and problem solved... Good that you kept the car with a low profile externally to avoid unwanted attention.. Def need a catch can M8 to keep ur intake clean..Cheers
  3. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    I like it,
    But unless Manley, Howards and ARP are paying you to have them stickers on, i'd be losing them.
  4. Kinng
    Kinng CrippleFK
    Straya ~ QLD
    VE Series 2 SV6
    Awesome as!
    I'm with kiddo, fk those stickers off
  5. Kinng
    Kinng CrippleFK
    Straya ~ QLD
    VE Series 2 SV6
    Awesome as!
