My 2004 vy ecotec auto is struggling under power and I'm not sure why any ideas?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Jordanb, Feb 4, 2019.
  1. Jordanb
    Jordanb New Member
    2004 vy commodore
    It struggles if i try to take off hard or accelerate hard from low speeds only seems to happen when i try to accelerate hard I recently upgraded these things trying to fix the problem including - spark plugs, coil packs, ignition leads and I also change the oil + filter and air filter pretty regularly I'm no mechanic but do all my own work on the car as I can't afford to take it to a shop so any help would be muchly appreciated thanks, Jordanb
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    Checked for error codes?
  3. Jordanb
    Jordanb New Member
    2004 vy commodore
    I don't have a reader but will an error code show up in the not sure the name of the mode some call it police mode or whatever you can cycle through the comp and it will come up with codes but all 0's
  4. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    Is the Engine Check Lamp on, on the Dash ?
    Also What Suburb you live in,
    As there are some members that may help you out, if you indicate your Suburb.
  5. Jordanb
    Jordanb New Member
    2004 vy commodore
    Nah mate no lights on dash or anything that would indicate a problem and I'm in weribbee​
  6. krusing
  7. Drewie
    Drewie Active Member
    East of Melbourne
    VX SS (Original owner).
    When did you last change the fuel filter? Might be partially blocked.
  8. tml678
    tml678 Well-Known Member
    HSV30 Senator (w/end), '00 Magna, '17 Carnival
    I'd give the throttle body a good clean too, the fact that it only plays up under hard acceleration might suggest that the butterfly is sticking a little when you give it a bootful.
    Jordanb likes this.
  9. Jordanb
    Jordanb New Member
    2004 vy commodore
    I'll look into that thnx mate
  10. Jordanb
    Jordanb New Member
    2004 vy commodore
    Thankyou could you recommend a cleaning method?
  11. tml678
    If you duck into SCA, you can buy throttle body cleaner. It comes in an aerosol can normally and is very easy to use if you follow the instructions. Read up on how to clean inside the plenum chamber as well. The ECOTEC's can get pretty grimy under there and it's well worth looking at to help with smooth running as well.
    I'd be looking at this for the throttle body:
    https://www.supercheapauto.com.au/p...ml#q=throttle+body+cleaner&lang=en_AU&start=1
    Jordanb likes this.
  12. Jordanb
    Jordanb New Member
    2004 vy commodore
    Legend thanks mate.
    tml678 likes this.
  13. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    When was the last time you changed the transmission fluid?
  14. gohrdrgomad
    gohrdrgomad Active Member
    Australia
    VxCaly57
    Have you ever unpluged the maff or tps etc without disconecting the - battery first. If so disconect for 10- 30 min allowing the comp to recomunicate/reset/recalibrate. Then see if any improvement after 100 km or so.
  15. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    You mentioned you changed coils. Did you change dfi as well?
    Have you checked wiring around cas & dfi plugs?
  16. Jordanb
    Jordanb New Member
    2004 vy commodore
    Like I said I'm no mechanic and am not sure what the dfi plugs are at a guess I would say direct fuel injector plugs and as of checking the wiring no I havnt over the next two weeks I'll give each of these a try I'll start with a throttle body clean then fuel filter ect I'll keep use posted on what hapns thank all very much for your help let's see how it goes haha
  17. tml678
    Please do keep us updated :)
  18. Jordanb
    Jordanb New Member
    2004 vy commodore
    Would the maff sensor be one of these two I would asume to messier air flow if so which one do I unplug and leave for abit I'll try that as have time to kill
  19. Jordanb
    Jordanb New Member
    2004 vy commodore
    I tried uploading a pic but it said it was two large I'm talking about the two what I asume to be sensors on the throttle body think that's what its called the bit between airbox hose and engine there are 2 sensors one on the side and one on the top just wondering what is which
  20. gohrdrgomad
    Australia
    VxCaly57
    Just the battery
