Modifying idle control when converting to manual
zeropalooba
VS Acclaim L67 manual
Hi guys, I hate starting new threads but I've had a quick search but no luck finding an answer. I have converted an L67 to Getrag manual. Everything is hunky dory but idle control.
Issues -
On start up the car idles at 2000 rpm for 2 seconds or so and then settles to 900 rpm where it idles beautifully.
When I drive a short distance (my driveway) in 1st, I have to put my foot on the brake to slow the car down.
When I disengage the clutch it revs at 2000 rpm for 2 seconds or so and then settles to 900 rpm where, once again, it idles beautifully.
I think these issues are all due to the idle control being set up for an automatic transmission. Does anyone here have any suggestions on how to get it to behave like manual when going into the idle state (no load, closed throttle) from some other state?
Thanks in advance.
lowandslow
NSW
V2 III Monaro
You'll need to get a manual tune memcal.
immortality
Staff member
Sth Auck, NZ
^^^^ Winner winner chicken dinner.
Utel67
Tasmania
Vs s3 ute
I believe he has a nvram from pcmhacking, (I don't tune) maybe you need to get the manual IAC settings from a V6 manual bin.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
I thought he had the manual tune on the nvram?
If so, maybe he should be looking at a new iac sensor or tps? Maybe both?
Utel67
Tasmania
Vs s3 ute
I think the nvram comes with the1's enhanced tune which is auto?
Lex
Geelong Victoria
Looks like l was wrong.
I thought l read in another post where he had downloaded the correct bin file & loaded that on the nvram.
Sorry, but not sure about the correct tuning terminology.
Utel67
Tasmania
Vs s3 ute
Maybe I might be wrong, what's that old saying two wrongs makes a right:D
immortality
Staff member
Sth Auck, NZ
Generally the guys selling the gear will load a tune on it for you but you still need to make sure it is correct for your combo.
Lex
Geelong Victoria
