Mitch's Vs Caprice
Discussion in 'VR - VS' started by mking, Mar 17, 2009.
  1. redvs2
    redvs2 New Member
    Raptor charged Vs, VY ss ute, rodeo daily
    Yeh would be cool to see who's is fastest down the qtr. Should be doing a run with mine soon
  2. VL_5SPEED
    VL_5SPEED New Member
    Newcasstle
    1986 Holden VL calais project
  3. mking
    mking New Member
    Newcastle
    Bagged vs caprice sII
    looking into getting a stage 2 shift kit installed, do you know of any good trans places vl 5 speed?
  4. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    if your getting a shift kit make sure you get a corvette servo. makes the auto a little bit more fun.
    it essentially ups the line pressure on the 1st-2nd shift and with a car in good nic you can chirp 2nd :)
  5. Trayner
    its also fuun when in the wet too
  6. mking
    mking New Member
    Newcastle
    yeh i put one in my old car i think il let a trans place do that agin lol it was a ****!!!!!!
  7. mking
    mking New Member
    Newcastle
    picked up the charger last sunday everything looks good, couple of hose lines missing like vacuum lines oil drain for charger fuel lines for regulator and pcv extensions etc but im going to pick them up today. Also need some bigger injectors new spark plugs and longer leads.
    Going to try and get my hands on a 12 psi pulley also
    Need to know where to get the boost gauge pickup from?
    And also are all the bolts on the serpentine setup reverse roatation ie. harmonic balancer?
    Also need to know where i can put my drain for the oil , does anyone know if oil comes all the way upto the top of the front of the sump ie. when you look down between your thermo fn shroud and engine and can see the top of the sump is there oil all the way to the top of that position. cheers
    Will get pics up of the kit soon
  8. Trayner
    cant wait for pics mate
  9. mking
    mking New Member
    Newcastle
    had a go at fitting the intercooler today, turns out i left my tools out the front of the worksite in thursday haha lucky no one took em but all i could get done was removing front bar and seeing how the intercooler and piping fit up , intercooler sits fairly low due to the top of the ic not fitting between the headlights and the piping being made for it to sit low so its a nice cop magnet also its 100mm thick so the bottom of the front bar needs to be cutout a little bit where its curves back towards the radiator, hopefully a series 3 bottom lip will cover the intercooler a bit more, also the drier had to be taken out and the trans cooler moved, lucky i install aircons for a living and will move the drier somewhere else, will get a pic up of the intercooler behind the bar tomoz, gotta wait till i get leads plugs injectors before i put the hole thing in, and an oil pressure gauge because the supply oil fitting i have has an oil pressure gauge already t'd into it, also need some info on making the dipstick the oil return for the charger, tapping into the sump seems like a ****around
  10. redvs2
    redvs2 New Member
  11. VL_5SPEED
    Newcasstle
    Seen this thing parked on the corner of my street a couple of times last week... selling up hey?
  12. mking
    mking New Member
    Newcastle
    haha in the backstreets at charly there thats where my work mate lives who i get a lift off sometimes when hes got my work truck, nah that number is the dudes i bought it off a year or so ago haha it burnt into the tint which got taken off yesterday because it was bubbling and **** i think it will stay off now.
    As for the charger im going to buy a smaller intercooler probably 550x300x76 as the one i have now is like 550x450x100, so hopefully ile be able to fit the trans cooler behind it easily move the drier and chop 100mm off each pipe that goes to the ic so it sits 100mm up from where the original intercooler sat, still also need to get some injectors and longer leads maybe ile see where i can move the coil pack to and im thinking of getting a 10 or 12 pound pulley but ile see what psi i get with this one first to see if it actually makes 15psi, anyone know of a good dyno tuner in newy area to see where i can get the air to fuel ratio checked etc after the charger goes on? and also im thinking my tune may need to be changed after i change the pulley to a bigger because the tune is for 15psi from chiptourque.
    cheers mitch
  13. VL_5SPEED
    Newcasstle
    haha yehh i noticed it didnt have the for sale sign on it this morning!
  14. mking
    mking New Member
    Newcastle
    oath ####ing loving the no tint, not looking forward to summer
  15. VL_5SPEED
    Newcasstle
  16. mking
    mking New Member
    Newcastle
    haha funny you say that, looking for some atm
  17. VL_5SPEED
    Newcasstle
  18. ethann
    ethann Low And Luxurious!
    Newcastle, NSW.
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Theres a dyno at heathrebrea.
    Heard his alright.
  19. Verynice
    Verynice Band
    VS Caprice 5L
    Looking killa mitch! Glad you went with sigs. Looks like jecs' :p You'll have to throw up some more pics man. Would look even tougher with the sIII front lip :thumbsup:
  20. mking
    mking New Member
    Newcastle
