Marinising a 304
EYY
VS Statesman
It probably won’t like being turned backwards either.. the fan won’t cool it properly too. Could try using an earlier Honda alternator as some of those are made to spin ‘backwards’.
VK SL 3800
VK SL 5spd
Alternator problem solved, putting a proper bulb in the system did the trick. It now excites and starts charging from start up.
I will look into fans and see if theres opposite blades available , im not sure what sort of temps it will see as its hardly under any load. No lights, fans or anything except the EFI system and pump. And the engine bay itself doesn't see the temps a car does so that gotta help a lot too.
So over all pretty damn happy, have all the issues last time out sorted.
Next step will be onto finishing off the hull with new carpet and vinyl wrapping some parts to make it a bit more pretty.
