[General] Make your own Transmission Manualiza plug for $6.00
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
I TAKE NO CREDIT FOR THIS MOD AS IT NOT MINE
Taken from L67torque.com from member VRTIDY
This is wired the same as the Transmission Manualiza plug that RVO and DTM transmissions are supplying for large amounts of money.
This transmission manualizing plug disables the Automatic gear change and allows the 4L60 transmission to be manually gear changed under full trans line pressure.
It will give a smooth manual gear change at low Revs/Power, and Hard as manual gear changes at High Revs/High Power.
1 x 4L60E transmission plug from a VR - VY Commodore loom. cut it off with between 100mm - 200mm of wire on it. $5.00
1 x IN5408 4 amp silicone rectifier diode. $1.00
4 X Stubbies of Harn light
Solder the yellow and light green wire on to the anode side of the diode and insulate.
Solder the yellow/black and Brown/yellow to the Cathode side of the Diode ( Side with the silver band).
supply 12volts from the ignition (reds) to the pink/blue wire to power the transmission.
Cut off remaining unused wires.
thesakeofit
vn
can u give more info on this as to wat it funy does in detail thanks
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
triggers the shift solinoids manually when you select gears instead of the ecu controlling it.it uses the gear position switch in the trans to directly activate the solinoid required for the gear you want
Red Ranger
Vn commodore executive
delco is this legit? Guessing if it is it would only work from vp onwards
sp001in
vyma100
QLD
VY ute
also how do you select 4th gear? Is D still full auto?
If I put it in D, is it going to be in 4th and have no take off power?
Red Ranger
if this is legit it is very cool, but the only car i would be game doing it to is the vn hahaha but that aint gunna happen :D
thesakeofit
vn
yer thats what i was thinkin as im getin a vn calais auto soon and ive got a engine and 5speed conversion already sitin in the shed so was thinkin of doin this for abit of fun thats why id lik some more details
F1carbonuk
45
Saudi Arabia
Chevy Lumina SS
Hasn't it already been mentioned that manualy shifting an Auto kills the box.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
obviously this looses torque convertor lockup and trans temperature 4th gear lockout good for doing an engine swap into an old vehicle with no ecu and a non-lockup convertor not so good on a commodore with standard convertor will cook the box if its driven at highway speeds without a non-lockup convertor and accompanying fluid mods inside the box for the TC
Taken from the other thread.
Transmission Manualiser
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
will only work vr onwards auto
