Machter water pump any good?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by losh1971, Aug 22, 2017.
  1. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Think I need a new pump as I have a leak. Are Machter any good?
  2. losh1971
    North Tas
    VR Ute V6
    Doesn't matter, I just bought a GMB off eBay for a decent price.
  3. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    they are just re branded Chinese ones I personally dont like the pressed on tin plate impellers..I pretty much always use gates stuff, much better build quality and Ive had one of those cheap tin plate ones fail within 400km
    VS_Pete likes this.
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I've used GMB with no problems.
    Good Luck.
    losh1971 likes this.
  5. crew_man
    crew_man Active Member
    VFII SV6 Reserve Edition Sportwagon
    I recommend Repco water pumps
  6. losh1971
    North Tas
    VR Ute V6
    Repco gear is normally good but 2-3 times the price of the same rebadged item from eBay or a cheap car parts place.
  7. greenacc
    greenacc Searching for the billion
    VE Berlina
    GMB has gone Chinese now. Hope the quality hasn't suffered too much, got one in my car too so fingers crossed.
  8. losh1971
    North Tas
    VR Ute V6
    Yeah I thought they might have been made in China now. Hopefully they are made under licence and have kept the build quality.
  9. koalasprint
    koalasprint New Member
    Wonga Park
    VFII SS MY17
    I just received a new GMB pump. Sadly it looks like they have gone to a pressed stainless steel impeller. The cast closed impellers are more efficent and less prone to cavitation at high RPM.
  10. greenacc
    VE Berlina
    Did you get the shaft wobble too?
  11. mpower
    mpower Well-Known Member
    you pay extra for that.
  12. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 6 speed Auto Wagon
    I went electric. I was sick of the crap, no matter the brand, or were you bought it.
    It also has an over temp alarm, plus temperature & voltage read out.
    There is more stuff it does.
    Check it out @craig davies if anybody is interested.
