Lowering VF2 SSV Redline Sedan
Discussion in 'VF Holden Commodore (2013 - 2017)' started by VinnieLS3, Mar 9, 2016.
  1. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    How much lower than stock are they?
  2. Paulie81
    Paulie81 Active Member
    NSW
    MY16 VFII Prussian Steel SS-V Redline Manual
    Approx 30mm [/QUOTE]
  3. JohnRedline
    JohnRedline New Member
    VFII SSV Redline
    [/QUOTE]
    Anybody want to buy my bilstein B8 plus eibach springs? Only installed in April and done just 5000km. I am going for coil overs. Don’t get me wrong though, the B8 and eibach are unreal in ride and handling. Make an offer.
  4. Clay1391
    Clay1391 Active Member
    Warragul
    Ssv redline
    Anybody want to buy my bilstein B8 plus eibach springs? Only installed in April and done just 5000km. I am going for coil overs. Don’t get me wrong though, the B8 and eibach are unreal in ride and handling. Make an offer.[/QUOTE]
    Where you located? I'd imagine they would fit my lowered Pedders springs too. I'm on stock shocks, with 20s and low profile tyres, the pain.
  5. Paulie81
    NSW
    Whats the reason you are selling?? FYI not sure if you noticed however Eibach have released a new set of springs for the VF. Previously they sold one set that claimed to have suited the VE and VF sedan. Now they have added a new set just for VF and changed the description on the original set to VE only. I contacted Eibach and they claim that the new set designed for VF has the same rear springs as the VE ones but the fronts are lower so you get a more even look of approx. 360mm on all four wheels. A bit annoying really but it is what it is. Personally I wouldn't want to go any lower that 370mm so the new Eibachs wouldnt be suitable for me. Id be happy with a set of springs that lower by 20mm on all 4 so that I can keep the stock shocks happy and not run the risk of scraping the undercarriage. Maybe Kings or Pedders?
    426Cuda likes this.
  6. JohnRedline
    VFII SSV Redline
    Thanks for the tip on the new VF eibach but a little pissed that I was sold what they said were VF springs and yes, was thinking of coilovers only because of the way the front sit. Mine at at 380 front and 360 rear. Otherwise everything else is brilliant including ride and handling so I will just replace the front springs with the supposedly new VF pro kit and it should look perfect. Cheers.
    Whats the reason you are selling?? FYI not sure if you noticed however Eibach have released a new set of springs for the VF. Previously they sold one set that claimed to have suited the VE and VF sedan. Now they have added a new set just for VF and changed the description on the original set to VE only. I contacted Eibach and they claim that the new set designed for VF has the same rear springs as the VE ones but the fronts are lower so you get a more even look of approx. 360mm on all four wheels. A bit annoying really but it is what it is. Personally I wouldn't want to go any lower that 370mm so the new Eibachs wouldnt be suitable for me. Id be happy with a set of springs that lower by 20mm on all 4 so that I can keep the stock shocks happy and not run the risk of scraping the undercarriage. Maybe Kings or Pedders?[/QUOTE]
  7. Paulie81
    NSW
    Yes and me too, however I suspect some other manufacturers are also making the same error. Pedders for example, their Sportsrider springs are being advertised to suit both VE and VF.
  8. Jaylaz
    Jaylaz New Member
    2015 MY15 VF SSV Redline
    Photoshopped, has diff wheels on it haahaha
  9. 3rspecB
    3rspecB Well-Known Member
    VF2 SSv Redline, White Manual Sedan
    No worries. So I guess this is also photoshopped too. o_O:rolleyes::p;)
    Anyway, this is what my rig looks like now with S1 Redline rims all round.
    Anthony121, Paulie81, SSteve and 2 others like this.
  10. JohnRedline
    VFII SSV Redline
    3rspecB likes this.
  11. struggo
    struggo Member
    Old Sydney Town
    2016 VFII SSV Redline + 2013 FG MKII G6ET
  12. Paulie81
    NSW
    I have not used the new ones, only the previous model. The new one uses the same rear spring but the fronts are lower. Here are some pics with the new model fitted (supplied by Eibach).
    VS 5.0, TTubrag, struggo and 3 others like this.
  13. panhead
    panhead Well-Known Member
    NSW Central Coast
    Cars
    Plenty of rake on those two cars, I think they've done a good job, sitting the rear up a bit is a classic look that's still the best way to go if you're going to be regularly carrying passengers.
    VS 5.0, struggo and TTubrag like this.
  14. struggo
    struggo Member
    Old Sydney Town
    Belated thanks for the feedback Paulie81.
    BTW, whom lowered those two vehicles pictured? Where are they located?
  15. Paulie81
    NSW
    Hey sorry for the late reply. I have no idea. The photos were provided to me by John at Eibach. Im guessing through one of their stockists. If you contact Eibach they will recommend workshops in your area.
    struggo likes this.
