Lowering VF2 SSV Redline Sedan
Discussion in 'VF Holden Commodore (2013 - 2017)' started by VinnieLS3, Mar 9, 2016.
  1. PeteSS
    PeteSS Active Member
    VF Series 2 SSV Redline
    Started taking my cars to Heasman nearly 30 years ago. Great guys to deal with
    panhead likes this.
  2. TTubrag
    TTubrag Active Member
    2016 VFII SSV Redline
    Look forward to seeing those pics LS1SS. One of the Bilstein or H&R options is where I think I'm going to land when the time comes.
  3. LS1SS
    LS1SS Active Member
    Milperra
    VF Redline.1970 Dodge R/T Challenger 440 six pack.
  4. LS1SS
    LS1SS Active Member
    Milperra
    These three fotos are Eibach springs and Bilstien shocks and half a tank of fuel,the rear I have reset the circlip to the top groove to eradicate the saggy bum look.
    RED LION and Paulie81 like this.
  5. bbunnys
    bbunnys Member
    New Zealand
    Holden Commodore VFII SS
    To save me reading through this complete thread. Have a simple question for those that have done it.
    Does changing shocks make a big difference to handling of VF2 SS.
    I purchased my car with Walkinshaw lowering springs in it already and has now done 40k on them. I want to get it handling better as feel its not great. So looking to maybe change out shocks. Mine is the base VF2 SS. So guess shock not that great.
    What are peoples thoughts. Was thinking of maybe chucking a set of Monroe lowering shocks in it. But is it worth maybe also changing out springs at same time. (I can get Kings at a pretty good price). Seeing they done 40k already.
    Or maybe better brands I should be looking at?
  6. LS1SS
    LS1SS Active Member
    Milperra
    There are some good posts here re suspension mods,just takes time to read and it will answer your enquirey,I have the same springs with non adjustable Bilstien shocks,the ride is firm but not harsh,if you have the $ go either Koni,Bilstiens,Boge,Pedders or Munro it all comes down to how much you want to spend but remember Bilstien non adjustable,Koni adjustable are the top $ shocks for performance.
    bbunnys likes this.
  7. [paradox]
    [paradox] Active Member
    VF2 SSV-R
    yes it will improve, spring only is never ideal.
    LS1SS gave a list of brands, it will all come down to budget.
    for a spring and shock combo i was recommended bilsteins, ive also had koni previously. they make an FSD which could be an option.
    walky springs are king springs, just painted a different colour, and slightly less harsh spring rate
    bbunnys likes this.
  8. RED LION
    RED LION Active Member
    SA
    VFII Redline
    Anyone just put some SL Kings on the standard Redline shocks? (sedan)
    I went SL Kings with monroe shocks on my old Calais wagon and they were quite good.
  9. 3rspecB
    3rspecB Well-Known Member
    VF2 SSv Redline, White Manual Sedan
    I have SL kings all round on my MY17 Redline Sedan. Transformed the car in looks and given me more confidence when going hard through Twisties. It does ride firmer than stock but not overbearing. I'm very happy with the ride n handling post spring upgrade and that's the main thing.
  10. RED LION
    SA
    VFII Redline
    Awesome. You didn't change the shocks? Do you have a pic?
  11. 3rspecB
    No I didn't change the shocks. Kings advised it wasn't necessary for SL springs. I also consulted a friend who was the suspension engineer for VF Commodore and he said their wasn't an immediate need to change the shocks as the car isn't a ground scraper with SLs fitted. He did say, the life of the shocks would be reduced but they will still perform as intended. When the OE shocks do need replacing, I will change to a Coilover setup. This is the best pic I could find.
  12. RED LION
    SA
    VFII Redline
    Looks like the perfect height/function balance.
    3rspecB likes this.
  13. bradp51
    bradp51 New Member
    OCT 2017 VF2 SSV Redline - Light My Fire
    I had my front wheel off the other day and noticed that the OEM front shock on my VF2 SSV Redline has a Monroe shock on it, I bought it brand new in March 2018 and it is a 5 Oct 2017 build. Mine is stock as a rock and I think it handles well.
  14. 3rspecB
    Yep, Monroe (Tenneco) was the OE supplier. Monroe also supplied the springs.
    I think Monroe also supplied the sway bars too but not 100% on that.
  15. Nastas_VF
    Nastas_VF New Member
    Mackay
    VF SS 6.2
    I had king SSL rear / SL front with stock FE2 shocks for a couple months. It drove really good but I wasn't happy with how high the front was.
    I then upgraded the shocks to Bilsteins and lowered the front to king SSL. The height is perfect for me, gets looks while driving but it can still get in driveways and over speed bumps. The shock upgrade wasn't as noticeable as I expected (guess I didn't know what to expect), rough roads and bumps will really rattle the car, but when you're on smooth road and into it the suspension is fantastic. Shame these North Qld roads are all trash.
    If I did it again I would get MCA coilovers, I know the Bilstein quality is raved about but I probably don't drive it hard enough for the real benefit. Coilovers would have given me the height and shock adjustability so I could get it how I want.
    TTubrag, RED LION and abuch47 like this.
  16. chunda
    chunda New Member
    south coast nsw
    2017 vf2 ssv redline
    hi I don't know if you have already purchased springs and shocks but I have just fitted ssl king springs front and rear. also I was told by kings that I need to get short shocks to suit. so I emailed and rang Munroe several times to make sure that i was getting the correct part shocks for ssv redline. Munroe sent ve shocks for the front which do not fit as the shelby suspension shop rang me who was doing the fitment. I said just fit with the standard shocks and I will wait for Munroe to send the correct ones out later. when I went to pick the car up the mechanic said that the car already has Munroe shocks fitted as standard and there was no benefit in having brought these so called short throw shocks. at least for sl and ssl springs .so I have wasted about 500 dollars. I read lots of posts here about springs and shocks which confused me as there were different opinions. my advice is firstly go to a reputable suspension service centre and ask for their advice. it is obvious from my phone and email conversations with king springs and Munroe that they do not talk to each other. I am happy with the height of ssl springs front and rear . I now have a set of new shocks for the front if anyone is interested in purchasing them.
  17. White Swan
    White Swan Active Member
    NSW
    VFII SS
    Maybe it's your mechanic that's giving you the wrong info
  18. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    another reason to go coilover units rather than split up springs and shocks between companies
    chunda likes this.
  19. chunda
    chunda New Member
    south coast nsw
    you are right, i probably did not save any money by getting springs and shocks. also at least with coil overs you can adjust the height to suit your needs . " live and learn ".
  20. Paulie81
    Paulie81 Active Member
    NSW
    MY16 VFII Prussian Steel SS-V Redline Manual
    I have posted my Eibach Pro Kit springs for sale in the forum classifieds if anyone is interested.
