Losh's VR Ute build thread
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by losh1971, Nov 11, 2017.
  1. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    How is the battery?
    Is it holding its charge?
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Yeah battery is kicking the engine over no problems at all now. Also miss on initial start has gone. Must have been infrequent drives and short trips. Battery will go on charger once a fortnight from now on.
  3. losh1971
    North Tas
    VR Ute V6
    Another run and it's 14deg outside. I left the bonnet open for over an hour and then checked the MAT. It really didn't drop below 44deg. I am wondering now if the runner tape is somehow increasing the MAT, anyone know if this could be the case? Intake pipe is luke warm, I don't get why them MAT would be hotter. Only other explanation is it is related to something else and I am not using the accurate testing methods.
  4. Dylan kingswood
    Dylan kingswood Active Member
    Hobart
    2011 s2 Ve ss
    What sort of insulation, it could be absorbing the heat ?
  5. losh1971
    North Tas
    VR Ute V6
    Just runner tape, Dylan. I have done some searching and it would appear that another member had a similar thing happen when he insulated his OTR intake. I am now wondering if the runner tape is actually decreasing the cool air flow over the intake tube, I'd say it isn't heat soaking the tube as such. I want to have another run tonight if I can with the tape on. Bonnet is up and outside temp should be below 14deg. Should cool the manifold a reasonable amount before I have another run.
  6. losh1971
    North Tas
    VR Ute V6
    Ambient of around 8-9deg this was the best I got with the wrap still on. Debating now whether to waste tape and try it without. I am thinking the heat shield is doing little if anything at all to lower MAT.
  7. losh1971
    North Tas
    VR Ute V6
    More results, testing has been done without the runner tape and best I got this time was around 41deg. I was wrong in thinking my MAT went up. I just realised yesterday I was on 36deg not below 30deg. Should have checked my logs better and or my posts. I am now thinking yes the wrap does lower the MAT. Bummed because I ripped it all off, oooops.
  8. losh1971
    North Tas
    VR Ute V6
    OK final test for the night. I am now confident the runner tape lowers the MAT. All I can put the high figure earlier today was probably a combination of heat soak and possibly higher ambient temps. I think the tape lowers the MAT by around 4 - 5deg. I felt the heat of the intake tube after a run without the tape and it was fairly warm, where as with tape it's barley warm.
  9. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    VS_Pete and losh1971 like this.
  10. losh1971
    North Tas
    VR Ute V6
    yes I have never seen one but they would help for sure.
  11. losh1971
    North Tas
    VR Ute V6
    Finally finished with my brake upgrades. I now have RDA slotted & dimpled rotors on the front, QFM HPX all round, fairly new DBA street rotors on the rear and braided lines all round. Unfortunately like i mentioned already i had to remove the caliper and did so before I realised i have no brake fluid in my main shed. Hopefully i can source some somehow tomorrow. May have to ask people on the town if they have a bit.
  12. losh1971
    North Tas
    VR Ute V6
    Haven't done much on the ute over the last two weeks due to flat out working long days. But because the money has been pretty good i have pretty much paid off a set of Mace rockers.
    I also have bought some engine bling that should be ready to fit around the time the rockers arrive.
    I was looking at an eBay all alloy rad and made an offer but now am hoping he doesn't accept my final offer, only because I have managed to order a heater core for $110, from the rad bloke across from work. Cheapest on eBay was over $130. So ideally i will get that in two weeks time and pay to have it fitted. I just need to get an estimate on time wise as i need to factor the labor in. I am thinking an hour but maybe two at the most. Not sure yet if this will help giving me some better heat in the cab but I think it is the next thing to eliminate.
    My current rad is fairly old and I do want to replace it but it can wait until later this year, especially given it is winter and I won't have any issues with it getting too hot until at least November.
    Plus I need to stop spending money on the ute, new tyres and an alignment last week set me back $285, for a couple of KU22s. I sometimes get carried away and forget i still need to finish my linen press in the laundry and save 300 buck for my racing licence before September, lol.
  13. EYY
    EYY Well-Known Member
    VS Statesman
    You can go to 'bids and offers' and retract your offer.
    Heater cores aren't fun to do, its a whole dash out job when you do it properly which will probably be more like 4-8 hours depending on who's doing the job. Unless you do the dodgy way and cut the pipes and it slips straight out. Can rejoin with heater hose and two hose clamps on each join. Plenty of people seem to do it without issue. The cooling system only runs at around 15psi from memory anyway (maybe 20?).
  14. losh1971
    North Tas
    VR Ute V6
    Yeah I am having it done by pipe cutting method. If I was to do dash out it would mean I have to do it myself as yeah too much labor cost. AFAIK the bloke who does them this way uses flare tool and flares the pipes after they are cut. Tried to get the rad tech near work to cut and join but he said no. The mech I sometimes use has an auto elect who does them the quick way, so he will get the job. If I had a leaking evaporator I would pull the dash out and do it myself but it comes down to my time coming at a cost and if it doesn't need to come out then it probably won't. If dash out was three hours work then I'd pay to have it done properly.
    Dash out is not out of the question, it would mean taking annual leave to do it myself but it's something I am not overly keen on just yet.
  15. losh1971
    North Tas
    VR Ute V6
    Hmmmmm do you think an A/C mech could do the job in four hours? Does the evap need disconnecting? I am wondering if I should have the box replaced as it did have a hole underneath near the drain, that I have since sealed up as it was dripping water onto the passenger floor. At least I would know all the flaps are working properly and the seals could be replaced. Just comes down to cost.
  16. VS 5.0
    Statesman conversion.
    losh1971 likes this.
  17. losh1971
    North Tas
    VR Ute V6
    I could but I believe some of my dash is bench seat specific?
    As mentioned I ended up purchasing the all alloy rad. I am thinking with the heater core I may end up installing it myself, using the chop and join method. I also want to have a look inside the core cavity and see if the sealant I squeezed in has somehow pushed into the space where the core sits, which is another reason for maybe fitting it myself. I did see one or two active members who have done the core this way are still around so might hit one up with a PM and get some advice, if that is ok Pete?
    On another note I only have a $100 left to pay on my rockers and was hoping a bloke was coming to look at my GT mountain bike. But since he hasn't turned up it might be a case of borrowing $100 off the wife and pay the remainder on Monday.
  18. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    Cut pipes & flange them.
    Done two that way in the past,compared to complete dash out job on my vp to gut everything out of it would never do that again if you want it all to go back in...
    Only difference with dashboard is plastic centre part above transmission tunnel goes down for benchies...cars with consoles centre piece comes out to meet console section...all removable anyway.
  19. vs-lover
    vs-lover Well-Known Member
    VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
    I have stripped a 45,000Km written off VS of every last nut and bolt many years ago and I started on the dash and after getting halfway through it I thought to myself I hope I don't ever have to put one back in as these things are a Mecano set nightmare. I pride myself on doing things properly and having every screw go back in to it's original spot, but I'd quickly spit the chewy bigtime doing one of these that's for sure.
    BTW Losh if the whole HVAC unit was to be taken out then the A/C evaporator would definitely require to be disconnected from the rest of the A/C system.
    Like I said................Nightmare !
  20. losh1971
    North Tas
    VR Ute V6
    Yeah I'm just gonna chop and join. Having pulled a dash out and refitted it due to a fairly bad heater core leak, i really think yeah do it the easy way. One i did had over 150 screws. It was more of a fleeting thought. I replaced the steering column in the ute and that was 3hrs by time i fitted the new bearing and mucked around. Full dash out would take me 10hrs. Plus there always the risk of the A/C developing a leak. Where as at the present it is icy cold and was regassed 18 months ago and no leaks.
