L67 Wiring Harness Issue
DeathSammich
21
Hobart, Tasmania
VT Berlina S1
L67 has been put together but won't crnak at all. I ran a wire on the starter motor and it tries to crank so it isn't faulty. I used a statement harness I believe and the engine is a VX l67 and it's in a VT series 1. I'm using the VT ecu and BCM with the Ecotec Memcal that was in it just to make sure it isn't a security issue. The light above the MODE button turns off when you turn the key but again it refuses to crank. I've got no idea what to do. Do I need to just use my VT Ecotec harness?
immortality
Staff member
Sth Auck, NZ
have you turned the engine over by hand to ensure it is turning freely?
Made sure the battery is charged and you have good positive and earth connections on the block and starter respectively?
DeathSammich
21
Hobart, Tasmania
VT Berlina S1
Found out the issue is you cant use the harness on a VT series 1.
