L67 Setup
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by DeathSammich, Oct 12, 2017.
  1. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Okay so this is going to be my setup
    L67 rebuilt with forged H Beam rods by mace, JE forged pistons, 10 PSI pulley, mace cold air intake, stage 2 shift kit, pacemaker extractors that go into 2 red back cats back into one 2 1/2 exhaust. All this in a VT Berlina. What kind of power and torque figures do you think this would Make? Much better than the stock ecotec I I originally had? Just wanted some opinions from people and what else you guys think I should add.
  2. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Any particular reason you are rebuilding the bottom end? The stock engine is capable of handling well over 400hp without needing to open it up.
    MACE should be able to give you a rough idea of what power gains the various mods make but it will **** all over a stock ecotec no problems.
    Stock the L67 makes 171kw/375nm of torque in the VT Vs 147kw/304Nm for the ecotec.
    I'd suggest you also get the 69mm TB, fit a cooler 180°F (82°C) thermostat and get a tune to suit.
  3. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Forgot to mention it has the mace thermostat lol. It's getting rebuilt because the previous owner destroyed a bearing and rod. Thanks :)
  4. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Also what would the 69mm throttle body Do?
  5. immortality
    Sth Auck, NZ
    The stock throttle body is designed to dampen throttle response. If you have a look inside it you will see a raised section on one side that effectively keeps the butterfly covered on that side until you reach about 15% TPS to give a nice smooth throttle transition for your granny to drive the car.
    If possible I'd try and track down another rod/piston as it may be a lot cheaper than those forged items. Those forged pistons/rods are major overkill for the upgrades you're talking about.
  6. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    The ones that were in it when I had it were forged as well. Near impossible to find stock rods around
  7. EYY
    EYY Well-Known Member
    VS Statesman
    With the 10psi pulley you'll have something around 145-155rwkw. Watch some dyno runs on YouTube.
  8. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    Might as well upgrade the cam while it's all apart if you got the budget for it
