L67 conversion VT
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by DeathSammich, Sep 10, 2017.
  1. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Is Putting an l67 into a VT a straight swap if you get the looms and ecu? Thanks
  2. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    not even that, drop engine in, extend TPS and IAC Wires. Keep your ECU just swap memcals over as yours is security linked.
  3. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Oh awesome, thank you :)
  4. harrop.senator
    harrop.senator Well-Known Member
    perth
    vr senator 355, vu 5 speed l67
    Bin files in standard vt not memcals isnt it theyre brown/beige plugs ? L67 is still a pink/blue pcm with swappable memcal. I used the l67 pcm for this. I repinned my factory manual harness and extended it.
  5. DeathSammich
    DeathSammich Member
    Hobart, Tasmania
    VT Berlina S1
    Can you use the stock ecotec transmission with the l67?
  6. harrop.senator
    perth
    Yes. The l67 flex plates needed though as has an added balance weight. L67 also has higher stall converter and 80 series diff. 75 will be fine though recommend lsd or locker though.
