Interior lights not working & a high pitched whine when i turn on the headlights??
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Dearic69, Jan 5, 2014.
  1. Dearic69
    Dearic69 New Member
    Watsonia, Victoria
    VT Commodore Berlina
    I have a 1999 vt commodore berlina, randomly the (after marker kenwood) radio stopped working. after investigating i checked the fuses and nothing was blown, i swapped the fuse in the head unit its self and it started working, however since then whenever i turn on the head lights, the interior lights (dash, odometer, rpm,etc) go really dull & the A/C, And the auto trans shift lights (P,R,N,D,1,2) just don't work at all... it also emits a high pitched whine noise that comes from the speakers...but as soon as the lights are turned back off the dash lights etc come back on again & the whining noise stops I've checked every fuse and none are blown... I've also removed the radio to check if it would work and it still does the same thing...
    it also has a sub & amp installed but im not sure if that has anything at all to do with it...
    & sorry in advanced if I've posted in the wrong section first time poster & really confused about the site lol. HELP!! :help:
  2. dirty hands
    dirty hands Active Member
    ipswich qld
    magna
    wiring
    I have a kenwood unit in my VT
    i am on a learning curve with my VT as well
    does you antenna raise and lower ..it is motorised
    you need to recheck all the wiring behind the radio even the earth
    and where your power for the kenwood unit is coming from
    your thread suggests you are wired into the dash or lighting power source some how
    and it is causing a power drain or overload may not be eneough to blow fuses but needs sorting
  3. bayse11
    bayse11 New Member
    Au
    vl sl, vt. R.I.P My VS Stato :(
    Sounds like you got a bad earth somewhere. Check ya earth wires. Good luck
