Injectors - Will VS-VY(Ecotec) fit VR (Buick)
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by JA2Z, Jun 15, 2009.
  1. JA2Z
    JA2Z Member
    East Gippsland, Vic
    VT 5L, WH LS1 Stato (Daily), TDCi Focus, Probe V6
    Hi Guys,
    I'm looking at some supercharged motor fuel injectors for my VR Series 2.
    Will Ecotech ones fit the Buick Motor
    Also any advise on psi:cc ratio requirements would be great (i.e. what cc rating injectors are recommended for different psi levels)
    Thanks
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    they will fit but u will need the fuel pressure reg to go along with it it runs at a higher pressure, but the VT+ injectors actually flow 1cc less than the VR-VS injectors.
    ur betting off going magna injectors, higher flow rate, and low cost.
  3. daron
    daron wizfiz
    adelaide
    VE SSV
    why do you need supercharged jectors
    they wont make anything better on stocker
    if your going forced induction magna ones wont cut it
  4. JA2Z
    JA2Z Member
    East Gippsland, Vic
    Dude, I have supercharged my VR (as you can see in my signature), hence why i'm asking about getting the appropriate injectors to suit the SC motor.:thumbsup:
    i've heard a bit about the magna ones, but yes i have also heard that they aren't good enough for SC motor, that's why i'm asking if the SC VS-VY ones suit
  5. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    if you plan to up the boost yeah 36lb S/C injectors fit will need a tune to run them and a tune for a 2 bar sensor forget about rising rate regs they arnt needed either just a waste of dollars and are not needed with a tune and big injectors
  6. daron
    daron wizfiz
    adelaide
    VE SSV
    sorry i dont read sigs but now i see you are chared at 4psi your injectors will be fine
    if you up ya boost do as delcokid says get the s/c 36's
