I need a Ve guru
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Rafeekee, Feb 16, 2019.
  1. Rafeekee
    Rafeekee New Member
    New Zealand
    Sv6 sportwagon
    Hey guys
    I have tried everything to fix this. Numerous mechanics and holden dealerships but still no luck. I have a 2010 VE sportwagon done 194kmz about 2 or 3 months ago I noticed the steering getting a bit tighter ( only low speeds parking and roundabouts) checked fluids no leaks everything looked fine. One day the steering jus stayed like that. Mechanics and holden places said the usual pump, belt, rack so I got them all replaced but still tight steering. I'm stumped!!! I have looked all over this forum and see a couple of posts about suspension bushes and tyre pressures I have 20" TSWz with 245/35 tires i pump them to about 39 PSI also have adjustable suspension. Now the front has no more adjustment left it's as low as it can go. Could that affect my power steering? The adjustables were installed and certed about 3 years ago and iv never had any steering problems until recently. Any tips or advice would b great.
  2. commy vk
    commy vk Active Member
    South Coast Region
    commodore ve
    8 year old car I'd be looking at struts
    If already work done has everything been put back on correctly.
  3. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    Excessive wear on ball joints and tie rods could cause heavy steering, also, flush the fluid and replace it with proper one (I know someone who topped it up with engine oil ).
    VS_Pete likes this.
  4. Rafeekee
    Rafeekee New Member
    New Zealand
    Sv6 sportwagon
    Its got adjustable suspension that's 3 years old and its certified so yes it has been put together properly. Did u even read the thread properly? Oh and were in 2019 bud its 9 years old. Chur
  5. VS 5.0
    Only if it was built in January or early February 2010.
    Tonner Matt and VS_Pete like this.
