[VR-VS] How To Repair Reverse Light Switch on Auto VR/VS Commodore
dilla1988
Australia
96 VS Equipe
Hi does this method work for 96 VS equipe commodore?
vombil
perth
VS V8 UTE
can anyone better describe how to adjust this switch? reverse light issue, not non-start issue.
i've read bending something with vice grips or just pushing something in the right direction??
MikeC
VQ Statesman
Thanks vsiicalais. Bought a second hand inhibitor switch for my VQ and it was in worse condition than the existing switch.
So I stripped down the existing switch , cleaned and adjusted it as above then lubricated it with WD40 before reassembly. Works perfectly.
There is no separate adjustment on this switch- it's directly connected to and adjusted with the transmission shift .
rickster8
VR Berlina
Tools Needed:
Phillips Head screwdriver
Flat Head screwdriver
Time Required:
15 – 30 minutes
Instructions
<!--[if !supportLists]-->1.<!--[endif]-->Remove the surround from the gear lever, it just pops out. Then remove the white piece as well, make sure you have disconnected the cigarette lighter and the light for the selector.
<!--[if !supportLists]-->2.<!--[endif]-->You should see the switch Refer to pic 1
<!--[if !supportLists]-->3.<!--[endif]-->Undo the two screws and unplug the connector. Then slide the switch off the transmission. Refer to pic 2
<!--[if !supportLists]-->4.<!--[endif]-->Now you have got the switch out you should have a part looking similar to mine. Refer to pic 3
<!--[if !supportLists]-->5.<!--[endif]-->On the side that the wires come off there is a little green clip thing, you need to push on that. Refer to pic 4
<!--[if !supportLists]-->6.<!--[endif]-->Whilst you are pushing on the green clip insert a screwdriver into the other side of the switch. Refer to pic 5
<!--[if !supportLists]-->7.<!--[endif]-->Gently lever the green piece from the switch. There isn’t anything in there that you have to be careful of. Refer to pic 6
<!--[if !supportLists]-->8.<!--[endif]-->Now you can slide the black bits apart and you should see the contacts on both parts. Refer to pic 8
<!--[if !supportLists]-->9.<!--[endif]-->Bend the contacts out until they are flush with or just outside the rim. Refer to pic 9
<!--[if !supportLists]-->10.<!--[endif]-->Once you have done that you can put it all back together again and test it in the car, after you have screwed it back down. Mine worked perfectly the first time. I also checked to see if the car would start in Neutral and Park. It was perfect.
Please note I will not take any responsibility for any damage you may cause to your vehicle by doing this repair.
<!--[endif]-->
Many many thanks for this terrific easy-to-use tutorial vsiicalais - easily fixed non-working reverse lights no drama, no cost. Awesome!
Matt Harper
46
VR Ute
For the absolute beginner, how do we find, and test out a reverse light switch for a 1996 VS column auto. Please and thanks
