How to install Power Windows
Wombles
Cars cost too much.
Mid bcm were in the acclaims. Ignore the low bcm part of his post and he is spot on what you have to do
Actually not all Acclaims have mid.. My Acclaim has a LOW.
aussie4life11
Keep It Simple Stupid
Western Australia
94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
Well the difference between your acclaim and my acclaim is mine is a vr where as yours is a vs. must have reduced the standard bcm to low when they released the vs
ephect
Donating Member
VS Acclaim V6
now im not sure what bcm i have, no biggy, power windows are working :)
aussie4life11
Western Australia
where are the relays located?
Wombles
Cars cost too much.
Under the steering column.
aussie4life11
Western Australia
Ohk. Anywhere in particular? Ive identified the 4 above the fuses. Theres only one other one that i cant identify. Its to the right of the steering column. Any pics of the relay/s im looking for?
DCEIVDU
Adelaide, SA
1990 VN SSV Enhanced 5.0, 1999 VT S Pac ll 3.8
Im currenly converting my vn exec into a vp calais and will be doing the power windowa in the next week or two. Thanks to this thread, this should be a cake walk :)
Sharon Strudwick
Tamworth NSW 2340
HSV VT Clubsport
Hi just wondered if u could answer a question for me r window regulators the same on a VT. ad a Clubsport vt
DCEIVDU
Adelaide, SA
Well instead of making a new post I thought I would add to this one. I recently installed power windows in my VR and I used the VN module so I could get the auto down and timer delay too. Only thing is that it doesn't activate when you unlock the car and when you lock it they stay activated for a little while after it's locked. I had this all wired up outside the car then all I had to do is run all the wiring and once all in the car connect the remaining wires like the Acc; door pin, earth and constant.
Markovr may add to this cos I know he had some other things to add to make them run better, but mine run fairly well so I didn't add them.
Im doing mine tonight. Should be fun. Im doing it all from scratch. Wish me luck
NickVR
Adelaide, SA
VR Executive A4 V8
No luck needed really. As long as it is done like the VN/my diagram, you'll be fine.
