How to install Power Windows
jbangr
VX Executive V6
hey bud was wjust wondering is this similar to a vx or completely diff, i have all four regs manin swith near gera stick all door looms and i thinki have to get some sort of module where could i possubly get this cheers really keen but dont know what to do
turmoil117
Donating Member
Armadale
Vs berlina
Does anyone know if I can wire up a vy/vz master switch in my vn?
MingeyMatt
VE SV6 MY10
Will be doing this very soon with my VT. Appreciate the write up
tezza
VX SS
The thread was a great help. I put the power windows in my ute today and its a real easy job. The longest part was getting the window back on the runners again, but that wasnt too bad.
Just need some switches now! Here are some tips I found along the way when fitting this to my VS ute.
- I used M6 bolts which fit through the door and power window bracket after drilling out the existing rivets
- The auto down function will only work with some low BCM's although no problems with a mid BCM
- Since I just changed the low 148 BCM to a 150 BCM, I didnt want to go and get another mid BCM, so I bypassed the BCM by connecting the green/black wire from the BCM to the green/orange wire in the door loom.
This enables the drivers window to go down, although you lose the auto down feature and functionality.
Here are some pictures
Tw1n Tur6o
VN Commodore
Cheers for the guide, almost finished doing mine just gotta clean up the interior.
Also what are the left over wires for on the plug?
tezza
VX SS
Which wires and plugs are you talking about?
tezza
VX SS
how much did it cost for all the parts?
Switches were about $30 for two rear door ones (mine went in a ute) and regulators were about $40 odd each from Pick n Payless.
I got the additional switch loom from Pick n Payless as well.
If your going to go and remove the regulators from Pick and Payless, bring a drill with you :)
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Cab someone tell me if VZ calais switches would work in a VP?
VN-855
A VN
any one know how to bypass the control module on the vn's ? bustin my chops tryna figure this out
