[VT-VX] How To Change Trans Fluid (PIC HEAVY)
aussieakito
Holden Dealer Master Tech
Melbourne, Victoria
forums.justcommodores.com.au
Do you have any idea where the Pressure Control Solenoid and Vehicle Speed Sensors are?
Or can anybody show me in the picture of the trans without the pan?
Thanks in advance. Mine came up in error codes a while ago and I got them in the mail
iphones made me post 3 times arg
Bezzey
Brisbane, Australia
VT 99' Series II
I'm not sure if that would make it any easier, I think it would actually be more fidgety.
If you're really having trouble you could but some gasket adhesive in each corner.
Technically you should be doing the bolts up from the middle not the corners to prevent the gasket from folding over its self.
This is what I was referring too...
Using the zip ties in reverse (simply to avoid wasting them) to align the gasket and stop it from folding etc. You then screw 1 bolt in each corner only a few turns then remove the zip ties.
Dropjeslover
**** happens
Emerald
VS V6 Executive
pics
That is a very, very smart idea!!
Both for undoing the pan and putting it back on!
This is how a (my) gasket looks like when you've tightened the bolts too much:
Don't tighten them too much!!
aussieakito
Melbourne, Victoria
i have done this 3 times since.
Havent over or under tightened once and i dont even have a torque wrench.
i dont use the zip ties and seem to get the gasket on first go without any worries all the time. :)
Ian Moone
Holden Adventra Lx6
It's common for folks to over tighten trans pan gasket bolts, and ruin the cork gasket. I did this job a while back on my F250 (can I say that in a GMH forum?) and there's actually a torque specification of 15 inch pounds for these bolts (1 & 1/4 ft pounds). You can get a small sidchrome torque wrench graduated in inch pounds (as distinct from its larger brother used in engine rebuilding graduated in foot pounds) just for this job...
This is a way to ensure you get the tension right (even) all around the gasket for a good seal without over tightening one spot and squashing the gasket out the side of the pan and voiding the seal.
It's an alloy housing for the pan and very easy to strip the threads if your at all ham fisted and prone to over tightening bolts. The inch pound torque wrench takes all the guess work out of it.
The wrench isn't cheap (at ~ $150 from memory) and it will sit in your shed like mine probably for years before you need to use it again but at least you then have it when next you need it.
I've always preferred to change the fluid from the cooler outlets while idling in drive with wheels chocked & hand brake on.
One clear plastic tube into a drum of new fluid, to be sucked into the trans by the fluid pump, and the other into an empty drum to take all the old fluid. Just idle the vehicle in park until all the old fluid is gone from sump torque converter, lines and cooler...you can see it all dark brown - when it starts to run fresh red and clean into the drum - turn engine off and re - connect pipe fitting to cooler!
Of course if you want to do the pan filter the best time is to then drop the pan (saving your new fluid in a container to add back in afterwards) and replace your filter and refit the pan with a new gasket and torque it up to specs. Then re add your new fluid. This is the BEST way to get the trans really cleaned out and a new lease of life. If you wanted too you can get your old trans fluid analyzed (westrac here in perth) to detect any problems headed your way with the trans due to excessive wear metals.
I did a mod to mine...where i added a large replaceable engine oil filter "in line" between the trans and cooler.
You do have a pan filter admittedly BUT when auto tannys go they often drop the torque converter first and send shards of metal thru the trans and pump and lines - blocking the cooler for eg...and the metal scores all the aluminium valve bodies in the auto trans housing making it in need of a complete rebuild. If you fir a filter in line to your cooler you can filter out all the metals bits before the fluid gets back from the torque converter to the transmission valve bodies - this - saving this major component from damage...and also keeping the trans cooler clean inside. If you do this and a torque converter lets go, then essentially all you need do is drop the trans and replace the torque converter....and your away again...
The difficulty for you in the commodores might be finding room for the filter - on my F 250 I fitted the filter body and filter up front inside the roo bar...and ran the rubber hoses too and from it to the cooler line also up front - simple cheap quick and effective - also adds another liter or so of fluid of your into heavy towing (which i am....).
I also fitted a transmission temp gauge to keep an eye on trans temps when towing as hot trans temps is what kills transmissions when towing.
used transmission fluid analysis results
Trans temps effects on Trans life.
Trans clutch pac wear materials on the pan magnet...
Too many people are scared of having a go at at their auto trans....a LOT of problems can be avoided with the right attention to detail.
M
magnumv8
Guest
Thanks guys, I need to do mine soon as I dont think its been done by the previous owner-thanks heaps.
immortality
Staff member
Sth Auck, NZ
I have a filter fitted in line with my external trans cooler, I'll see if I can find a pic later.
I also have a trans temp gauge, however I recently learned I should be measuring the trans temp fluid after the cooler rather than before as it's more reflective of the actual fluid temp in the pan rather then the extremely hot fluid coming straight out of the converter.
When changing fluid I just pump about 4 litres out dropping the fluid cooler feed line, whilst idling the car in neutral.
Shauno96
Australia
VS Acclaim S1
When I drop my trans pan i use a cheapo trolley jack (1500kg) and a big flat piece of wood to support the weight of the sump pan and wood to protect it of course =).
With the weight of the sump full of oil supported evenly its easy to undo all the bolts and remove them..then carefully lower the pan with the jack (keeping out of the way of any spills lol) and roll it out on the jack, once out from underneath car just pick it up and empty it into wherever.
I use the jack/wood to raise the empty clean pan with the gasket installed on it up into position slowly (so gasket stays in place) til the pan starts to "mate" with the trans bottom (be careful to not raise the jack too much or u may damage ur pan or lift the car up which in either case would be bad lol).then install all the bolts by hand til finger tight..then do them up with ratchet..then drop the jack and remove it, then I double check all bolts are properly tight =)
I barely get a drop on me throughout the whole job..takes me 30mins tops...just my method......
Husky
Pakenham
VXII L67 Berlina Wagon and VEIISSV M6 Sportswagon
Would it matter if you did this on ramps? As in undo the pan, change the filter, put the pan back, then let the handbrake off and roll the car back onto level ground and start filling the oil? Or could I put 4L in then roll backwards in neutral?
