How to change Ecotec Waterpump
danoz vt vz
casino
svz vz 06 vt olympic edition
If im dumb enough to remove the belt without taking the pulley bolts out I just put a pair of 8mm socket or spanner east west on the pulley wheel and wrench.
Grant 3.8 vx
56
Western Australia
2001 VX Berlina wagon
I have replaced water pump with a true flow 9000 ,it came with two gaskets for the pump and a spacer for the pulley now I have a squealing noise coming from the pump, dumb question but was I supposed to fit both gaskets when fitting new pump or have I got the wrong pump, cheers
immortality
Staff member
Sth Auck, NZ
Not likely. The early V6's need to gaskets as they have an extra plate between the pump and the timing cover. Try it without the spacer under the pulley. Squealing noise is most likely the belt/pulley.
Grant 3.8 vx
56
Western Australia
Thanks I'll take the spacer out and see how it goes,, when you say belt/pulley do you mean it's possible I need a new belt or a pulley or both, sorry for the dumb question, cheers
immortality
Staff member
Sth Auck, NZ
Have a look at the pulley and see where the belt is running on it. Most likely an alignment issue between the belt/pulley.
mirrabucca
69
VX S pack (Devil Yellow)
Old thread I know, but I have a tip that may be useful.
Rather than lose coolant when you replace the pump or do other minor work on the cooling system (new hose, thermostat etc) you can drain some coolant down to just below the water pump level by removing the lower right hand (as you face the engine) water pump bolt. It's better if you first remove the drive belt and the idler pulley above the A/C pulley
Make sure the engine is cold, rmove the radiator cap. Place a small funnel under the bolt, and have the other end of the funnel going into a bucket or large flat plastic dish. (I use a oil drain pan).
  • Like
Reactions: Lex
