How to change Ecotec Waterpump
VS_Pete
Donating Member
7) use a little non-hardening silicone (the red RTV silicone or locktight 2{spelling?}around the entire gasket area of the water pump and block, then add the gasket supplied (so the gasket is between 2 layers of silicone) Dont use so much silicone your cleaning it off for a month, but enough to seal it.
Hi guys.
Can I just use good old Gasket Goo on gasket and bolts (I have some at home)?
I use it on the thermostat housing and bolts with no leaks.
On the older cars you could move the fan blade to see if the bearing was bugged.
I did this on the VS water pump pulley and have movement.
Cheers guys.
aussieakito
Holden Dealer Master Tech
Melbourne, Victoria
forums.justcommodores.com.au
Yep gasket goo is the go,
by gasket goo you mean the honey like smelly stuff that is usually in a tin?
thats perfect to use on the gasket and bolts
VS_Pete
Donating Member
This one.
Brownie colour.
VS_Pete
Donating Member
Cheers mate thank you
VS_Pete
Donating Member
Well did the pump yesterday bit warm up here so I`ll let the gasket goo dry over night then I`ll fill up and check for leaks.
I found out the steering pump pulley has to come off aswell so back on with the belt I was pissed.
Samwow
Sydney, Australia
2000 VT Olympic 3800 Ecotec
Hi All, Great thread!
I recently started getting a weird noise from under the bonnet of my VT 2000. It was indeed coming from the waterpump.
I followed this guide above and also hit a snag when it came to removing the circular pulley wheel which sits in front of one of the bolts on the water pump.
Down to Autobarn and bought a 75mm Claw Pulley remover. I used a 17mm spacer when trying to remove it, but this was too big and I ended up both pushing the pulley and pulling it off at the same time, scratching my head as to why the darn thing wouldn't come off! Once I worked out how dumb I was, I changed the spacer on the pulley claw remover to something that fit in the middle (a 10mm one I believe) and the pulley came straight off no problem at all. I was then able to get the water pump off (extremely corroded, noisy and in bad shape) and replace it with a nice new one from ebay. I used a razor blade and then some light sandpaper to clean off the surface, sprayed the surface (and the end of the larger waterpump bolts) with with hylomar, put the new gasket in place and screwed it all back together. SHE'S ALL GOOD NOW! :) Happy days. :)
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
It's funny, I've done a few ecotec water pumps and never had to remove any other pulleys. Pull it out and angle it so it comes out behind that pulley. That's all I have done.
Samwow
Sydney, Australia
Hmmn, hey actually that might have worked! It's pretty tight but might be able to squeeze through once loosened. I didn't think of pulling it out at all until I had all the bolts off. Don't tell me I wasted $55.00 at AutoBahn on a claw pulley remover. Haha. Nah, I have no regrets. I might use it again.....one day....
