How To: Change a VF Steering Wheel
Kim
2014 VF Evoke Wagon
Just did a steering wheel change on my VF Evoke wagon. Thanks so much for this post. It really made the job very easy. I found that the aluminium bolt in the centre of the wheel was fairly easy to remove for me. The whole job took about 20 minutes to remove the wheel and transfer over the controls to the new wheel.
Ron Burgundy
NSW
VF II SS
Good how to thanks guys !
3 things I would like to amend/add to your guide is
1 - I found using an allen key or L shaped torx rod easier to use than the screw driver to press the clips in with
2 - When placing back in the 3 x 30T bolts into the steel plate press the plate all the way in to see where the horn mechanism finishes, then screw your bolts in so there is only a small amount of travel for the silver plate and not a few mm like i first did (like chasie I had to do this a few times to get the horn working again)
3 - tighten up the steering wheel bolt as per workshop manual
Also I re used the orignal bolt and used a little bit of loctite as there was a blue thread locking substance from factory.
Thread dig....
Do these three bolts actually screw onto the 3 raised sections on the steering wheel ? I just got new steering wheel and dont see any threads in those holes...
lmoengnr
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Thread dig....
Are they spigots that the horn/air bag pad springs sit on?
Ron Burgundy
NSW
VF II SS
Seems like it but I am not certain whether those 3 torx screes need to be removed at all for steering wheel swap if they are not screwed to those spigots...
It's throwing me off as the holes have no threads...
Would rather hear from someone that did this than learn on the job :)
