How To: Change a VF Steering Wheel
MrMagoo
Surfers
2013 VF SS
Can i ask has anyone attempted this lately..... or any chance of a youtube instruction vid for us lazy noobs?! I would love to chance my steering wheel to one of these :boxing:
Smashfist
41
SE QLD
440rwhp Cammed VF Ute
I did mine today.
-Tighten the bolts holding the horn mechanism all the way, they bottom out and don't take up all the travel.
-Clock spring is fairly loose (moves easily), I put a little masking tape on it to stop it turning too much. Check to make sure the loop of ribbon cable is still in the little inspection window before refitting the wheel.
-The hardest part was swapping the controls between wheels. Slow and steady with a trim removal tool.
blackve76
45
there
VE SS ute 360rwkw N/A, 2016 VF2 SS M6
easy as to do, just the 50T was tight otherwise all good
Great thread
treesnake
VF Sv6 SII Sedan
Yep easy to do, great writeup thanks!
If it wasnt for the tight T50 torx bolt, I think I would have swaped it all over in under 10mins.
How much did Holden charge you to program the paddles ? Ive been quoted $150 which is perhaps steep for a 5min job labor time?
Super Coach
GTS, S, CV8Z, SSVR
HT GTS, VN S PAK, VS S PAK, CV8Z, VF2 SSVR, MSE
ok so just a question, wanting to do this on my VFII which has push button. How do I turn the steering wheel if there is no power and without the steering lock coming on?
pat rum
Penrose
vs senator vf ssv vf ss vt ssL67
I had the key in the ignition and tune it straight and it's so easy
Mavericks Choice
NSW
VF2 SSV M6, VF2 LS3 Calais V, VZ 6L M6 Crewie
Wives tale about SRS deploying by themselves & no need to pull fuses or battery.
Done many Holdens without disabling SRS.
VFss60
51
VF SS
Thanks for the great instructions, it took me 18mins from start to finish and that was with a OCD dusting in the middle
VFss60
51
VF SS
It was a piece of piss, took me 18 mins
Mike Litherous
VE ssv
Is it doable to retrofit the vf steering wheel to the ve?
