How to Change a Starter Motor
Graeme Kimber
67
Bennett Springs WA 6063
Clubsport VZ
Im about to fit a new starter to my VZ Clubsport LS2 as its on the way 0ut, well the contacts in the solenoid are as it has clicked couple times. i am wondering if its possible to remove the 2 vertical mounting bolts plus the horizontal one at the front then pulling it out with all wires still attached, remove wiring when its clear of the header, clean up terminals and putting it back in position and fitting mounting bolts.
Ive read the above methods, but wondering if this method is possible. cheers
rambunctious
Alexandra Headland Qld
VZ Executive Wagon and VZ Ute
No idea but you are about to find out so then you can tell us but please
disconnect the battery before you start.
  • Like
Reactions: Lex
