How long did your brakes last ?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Ron Burgundy, Nov 30, 2018.
  1. LS1SS
    LS1SS Active Member
    Milperra
    VF Redline.1970 Dodge R/T Challenger 440 six pack.
    Mine does all of the above,when we get to where we are going my legs ache from pushing the carpet thru the floor,but the thing I hate is the blinker doesn’t come on till the wheel is moved left or rite around a corner and not before,shits me no end.
    tml678 and Ron Burgundy like this.
  2. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    Ah, no... don’t you find you’re always filling up her car :rolleyes:
    immortality, tml678 and Ron Burgundy like this.
  3. Gmac 2.0
    Gmac 2.0 Member
    Melbourne Victoria
    SSV-R Manual PBM Ute
    I got about 50-60K (from memory) before replacing front pads and rotors on my Brembo'd VE2. Manual too, which tends to lessen wear I've found.
  4. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Yeah, but until recently it was "ours"
  5. 426Cuda
    426Cuda SUBLIME!
    Wagga Wagga
    VF Redline Sedan - A6 Spitfire MSE...
    Don't forget the lane changes. Holding the blinker stalk, while looking in the mirror, waiting for a gap, then hit the indicator and move the wheel. Viola, lane change successfully executed!
    Apparently if you indicate first, other drivers will hit the brakes, swerve to avoid an inevitable accident, or in high risk situations, just go straight for the ejector seat button...Who new?
    Paul Cordingley likes this.
  6. KT11H
    KT11H Active Member
    VFII SSV Redline Ute
    Have had 45K service on my VF2 redline ute last December and brakes are all right according to the dealer. I think fuel consumption is a good indication of how people drives, my ute is averaging 12.5 litres/100 km.
    saroadie, 426Cuda and Anthony121 like this.
  7. Calaber
    Weeeelllll..... Continuing on from my last post in this thread regarding the other half driving.
    Yesterday, picked the granddaughter up and started driving home. Approaching a Give Way sign, with traffic crossing, and we aren't slowing down, we're accelerating!
    Yelling "Give Way sign" worked. Just. Farrrrrk.
  8. Pablito
    Pablito Well-Known Member
    Central Coast NSW
    VF Redline, VE SS
    FYI.....had a 3rd mechanic tell me the rotors need doing same time as pads with Brembos...........:confused:
    I'm confused. The rotors look good!
  9. VS 5.0
    I have the same type of experience with speed limit changes.
  10. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    Measure the thickness and see how far are they from minimum thickness.
    How many kilometeres did you do so far ?
  11. Skylarking
    Downunder
    Just be sure to measure the disk thickness without the lip on the outer edge...
    Oh, and usually the minimum thickness is embossed somewhere on the rotor itself so have a look.
  12. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    some women and some men. That said mine does similar and doesn't understand the balance or lines in cornering. She will also accidentally lose traction everytime single time the car is wet but hates when I do it controlled.
  13. Ron Burgundy
    NSW
    VF II SS
    I am now at 40000k and pads are down to about 3mm. Time to replace them...
    Current stock brakes are actually really good with front heavy duty 345mm front rotors and HP1000 pads. Rears are stock rotors and Bendix ultimate pads. Booster and BMC are also upgraded from the factory...
    I have front and rear set of DBA T3 rotors ready to go and I also bought Remsa pads for this setup. I hope it will be as good as the current brakes !
    I researched many brake pads and landed on Remsa. I had them before on SV6 and they were great except for brake dust !
    Skylarking likes this.
  14. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    Replaced pads and rotors at 85,000 keys, bought genuine pads (oem ) on line for $25 delivered.
    Ron Burgundy likes this.
  15. Calaber
    I don't know what compound is used for the standard pads in our Captiva but at 107k, the factory originals are still there all round. The last time I checked them, about six months ago they had well over 50,% left on them. They don't squeal, no brake dust and a light but firm brake pedal with effective retardation.
  16. Ron Burgundy
    NSW
    VF II SS
    Probably organic or some odd hybrid of organic and ceramic...
  17. Paul Cordingley
    Paul Cordingley Member
    VF SS-V Redline MY15 Series 1
    Drove the wife's car (Elantra) for the first time in ages about two months ago. Had to start it four times until it took - kept sputtering out. This is push button start. She said "yeah it's been doing that for ages." Me - deep breaths - "if you notice anything weird with your car tell me straight away", again.
    A rag, some throttle-body cleaner and 20 minutes of work later, and starts like a champ again and has since. It's amazing to me how a thin coating of gunk on an otherwise large throttle opening can have so much effect.
  18. greenacc
    greenacc Searching for the billion
    VE Berlina
    Did the rotors actually need doing at those ks or did you just choose to? The rotors on my VE lasted double that and more.
  19. Anthony121
    Anthony121 Well-Known Member
    VF SSV Redline MY17 & VF Director
    The Brembo brakes on the VF do not last that long. My discs at 42k are undersized and I am not hard at all on the brakes.
  20. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    40k on my Magnum, all the rotors are 'very' worn, plenty of wear left on the pads...
    Got 49k out of the Maloo brakes, every rotor was below minimum thickness, and still wear left on the pads...
