Hot under dash
Mickbez
37
Weston NSW
VS Statesman 5L
Hey all, I noticed it was getting really hot near my left leg in the footwell and all the dash plastics were hot hot. Pulled it apart and there is what I assume to be heater pipes. I don't know what's up. Possibly the heater tap is stuck open and its cycling hot water through?
VK SL 3800
VK SL 5spd
Looks like you have the climate control setup, check the heater tap is getting vacuum supplied when you have it set to full cool. Other wise coolant will flow and make unnecessary heat.
Climate control have a solenoid controlling the vacuum line which may have failed causing it to not turn the heat off.
Mickbez
37
Weston NSW
VS Statesman 5L
I'm playing around with that vac solenoid as we speak. I'm pretty sure its the problem. Thanks mate
61
VS II 5 ltr Berlina Wagon
I've owned my VS 5 Litre wagon now for almost 20 years and it does the same.....pretty sure it is always hot and the climate control mixes the air to the temp you selected. Is a concern though because if it ever sprung a leak I'd hate to think of the 3rd degree burns you'd receive !
