Horn/cig lighter
Discussion in 'Electrical Wiring / Questions' started by Sharky1, Dec 3, 2019.
  1. Sharky1
    Sharky1 New Member
    Australia
    VT S pack
    I recently bought my VX. The horn fuse was missing. Put one in & it worked fine. A week later at 2:30am my horn beeps continuously (not the alarm). I couldn’t unlock the car with the remote thats 6 weeks old & working fine. Couldn’t get it to unlock manually either. In the end I got in manually & alarm horn starts too. Got that to turn off with remote. Ended up locating horn behind bumper & unplugging it. Next morning I plugged it back in & it won’t work & now my cig lighter keeps blowing fuses & that was working fine before. My question is can these two be related via the horn relay & can a dodgy relay cause all this or is it likely something more like the BCM?
  2. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    The horn maybe a stuffed horn pad or a short in the horn it self , . The 2 are on completely different fuses, both the horn and theft horn relays are in the engine bay swap them out, they can stick so rule them out first then only leaves horn pad and horn. The cig lighter well that probably stuffed so replace it, also unplug it and see if the 20amp fuse blows if so then its a wire short.
