High beams staying on, random alarm going off
Discussion in 'Electrical Wiring / Questions' started by dawnbeaver, Dec 5, 2019.
  1. dawnbeaver
    dawnbeaver New Member
    NZ
    Vx Ls1 Mafless OTR and exhaust (MOE?)
    Hi guys
    VX Ls1 Calais... When I flick the high beams on using the indicator stalk they stay on, wont go off, remove high beam relay - high beams still on. Remove relay and then flick indicator stalk, nothing. Factory alarm going off at random just to cap it off... I assume a short (to earth or another wire?) in the return wire (light green) from headlights to relay. But why does it take turning the high beams on before they get stuck on. If it was a short, I thought they would just be on all the time.
    Any ideas before I start running new wire from headlights to relay?
    Thanks, really appreciate any help here.
  2. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    Relay needs replacing or indicator stalk faulty?
    I'm guessing.
  3. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Try removing the fuse as well to see if they still on? that will rule out a short or not, you can also try removing the harness from the stalk and bridge the high beam lights to find out if its the switch or a wiring problem. I'm pretty sure they activate by the earth lead so it be a negative wire staying open . It could be your bcm, maybe a reset might fix it.
  4. dawnbeaver
    NZ
    Problem solved... A short circuit to earth in the light green wire that runs from the headlight high beams to the high beam relay. Ran a new wire and works fine.
    VS_Pete likes this.
  5. Trevor loves holden.
    vs commodore
    That happens when you run higher voltage lights.
    VS_Pete likes this.
