Help please VH commodore hazards come on when i indicate
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by Morg's VH, Nov 20, 2019.
  1. Morg's VH
    Morg's VH New Member
    Blacktown
    1983 vh sle
    So my alarm went off for 7hrs straight in my VH and 2 days later i went for a drive and i went to turn left put my indicator on and the hazards come on.
    I have checked both relays all good.
    Indicator stalk is fine . . Any body got any ideas PLEASE i just spent 2G on the front end so cash is super low thats why im hoping to fix myself . . Thanks
  2. Lacksballs
    Lacksballs Active Member
    VK Group C Replica
    Disconnect your alarm from the vehicle wiring harness & recheck.
  3. Morg's VH
    Blacktown
    1983 vh sle
    Thank you i will try that in half hr n let you know.
  4. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Hazard switch gone bad. Replace.
  5. Trevor loves holden.
    vs commodore
  6. vt_II_senator_sig
    vt_II_senator_sig New Member
    VT II HSV Senator Signature
    The advice above is probably correct...
    but i once accidentally broke off the earth wire in the boot to one of my tail lights, and then it sent the lights weird whenever i indicated. from memory my earth wire was just joined to a screw inside the boot near the light assembly... might be worth a look, just incase... but i dont see how this would set the alarm off... but its a 2 second check...
  7. Trevor loves holden.
    vs commodore
    Not sure if you can fix the pins in those or not, I would say no, 7hr flashing is keeping the circuit on for flasher on one side maybe stuck in the closed position, maybe you can spray some contact cleaner or even try tapping it, better off replacing it in the long run, good luck. .
  8. Morg's VH
    Blacktown
    1983 vh sle
    As in the steering colum
    As in the steering column??
  9. Morg's VH
    Blacktown
    1983 vh sle
    Disconnectted alarm still got the problem
  10. Morg's VH
    Blacktown
    1983 vh sle
    Thanks ill check that.
    Im just thinkn something has burnt out as the mrs cat wouldve jumped on the car set the alarm off n due to the fact the alarm with hazards was going for hours something has fucktarded out but what
  11. Morg's VH
    Blacktown
    1983 vh sle
    Yes sorry just clicked your link thats what im hoping sorry for delay im fresh with all this
  12. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    Have you tried pulling the hazard relay out then try turning the indicators on.
  13. Morg's VH
    Blacktown
    1983 vh sle
    Will try that tomorrow thanks
