Help I've tried everything
Discussion in 'Electrical Wiring / Questions' started by Brooke May, Nov 21, 2019.
  1. Brooke May
    Brooke May New Member
    Andrews farm
    Vr statesman
    Hi everyone well my vr statesman started running rough then it took twice to turn the key before it would kick over. Then it started splattering and back fired. And next time I try to start it it just wouldn't kick over. Now I have power to my stereo my clock my central locking and my immobiliser goes off but no dash cluster lights or anything from engine not even an attempt to click over or start just straight out nothing. I've changed all fuses under dash and under bonnet . Prior to that I had changed leads and sparkplus.
  2. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    Sounds like a ignition switch issue.
  3. Trevor loves holden.
    vs commodore
    What about those big fuses with the clear tops? Wiggle the wires around near the fuse box, might be a loose wire.
  4. Slowvxss
    Slowvxss Member
    Tasmania
    Vxss
    Had the same issue year's ago turned out to be a stuffed battery, borrow a battery to try.
  5. shane_3800
    shane_3800 Active Member
    places
    vr commo
    You tried all these things execept calling a mechanic so im calling false thread titling.
  6. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    ^ haha, that was my first thought :rolleyes:
