Headlights. Polish or Clearcoat?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by ONROADYNO, Nov 24, 2017.
  1. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    I have just polished my headlights and are happy with the outcome.
    Should I clear coat them?
    For and Against please.
  2. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    If you can find a headlight UV clear coat, I would try that.
    I've polished many pairs of cloudy head lights, tried to seal them with a UV sealant, but they usually start to get cloudy again after a few months.
    ONROADYNO likes this.
  3. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
    yeh same
    I used marine grade UV clear coat and after a like 6months started to yellow
    Once they start to yellow, can never permanent fix
    I found headlight restorer and once a month Turtlewax Headlight Cleaner and Sealant to be pretty good
    http://www.supercheapauto.com.au/Pr...MImYL6gP3Y1wIV0xwrCh0yGgChEAQYAiABEgJAx_D_BwE
    lmoengnr likes this.
  4. VT&VX
    VT&VX Active Member
    VX Acclaim
  5. ONROADYNO
    ONROADYNO Member
    VY SS UTE
  6. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    This makes sense as when the plastic is originally moulded it would be hot.
    Never heard of this but very interesting.
    Thankyou.
  7. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    This is the problem when manufacturers use components suited to Europe or cooler, less UV intense environments than ours.
    I don't think any manufacturer makes plastic headlight lenses that won't discolour or fade over time in our climate. Good old glass had a lot going for it.
  8. EYY
    EYY Well-Known Member
    VS Statesman
    Sand with 800-1200 and clear them.
  9. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    I couldn't agree more. Not made to last, just cheaper to make and will need replacing.
  10. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    I am thinking about clear coating them. What type of clear would you suggest? What about a plastic adhesion promoter?
    My biggest fear is melting the plastic throw a bad reaction.
    Cheers for your input.
  11. Mattricho
    Mattricho Active Member
    VF SSV my15
    You could try this
  12. EYY
    VS Statesman
    I've done it with colorspec crystal clearcoat. No adhesion promoter, just make you sand the lenses back well to avoid reaction with any previous coatings.
  13. mpower
    mpower Well-Known Member
    buy new ones while you still can (originals not chinese eBay junk) they'll be good for a lot longer. If they haven't already GM will stop making these. As a plus new ones come with a full set of globes. :)
  14. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    Thankyou
  15. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    I am going to try this method.
    Thankyou
  16. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    I tried this method and even got the same Clear at Bunnings.
    Came up great after first spraying then rubbing back orange peel then applying a second coat.
  17. Mattricho
    VF SSV my15
    hey ondoadyno how did you go with your headlights??
  18. evBenji
    evBenji Well-Known Member
    VY Commodore
    i been using Autosol on them at work then proper glass polish and they came up unreal
  19. ONROADYNO
    ONROADYNO Member
    VY SS UTE
    Awesome thankyou.
    I watched the video you posted and bought the same brand paint at Bunnings and cost $20 total, paint and the iso cleaner.
    Thankyou for your help.
  20. Mattricho
    VF SSV my15
    All good Glad I could help! Let us all know how your headlights hold up over the next couple of months??
