Has anyone cammed their VF series 2 yet?
Discussion in 'VF Holden Commodore (2013 - 2017)' started by SS Flo Rida, May 21, 2016.
  1. SS Flo Rida
    SS Flo Rida Active Member
    Gold Coast
    VF Series II SS W375
    I'm booked for a cam upgrade for my VF2 W375 auto in July and wanted to ask if anyone else has changed their bump stick and how have you found it?
  2. 43lr155
    43lr155 New Member
    VF2 SSV redline
    Which cam are you going to install?
    I had a VCM10 in the VE but I was thinking a VCM11 or VCM12 for the VF.
  3. SS Flo Rida
    Gold Coast
    I'm going with a 224/230 112lsa and 600-610 lift
  4. bradles024
    bradles024 Member
    Australia
    BA XR8
    Is yours an automatic? Are you staying with the stock stall?
  5. Revhigh
    Revhigh Member
    Dandenong South
    Holden VF Maloo
    If you want any recommendations on VCM Cam upgrades let me know. Can do them at mates rates for JC forum members :)
  6. SS Flo Rida
    Gold Coast
    Yes mate it's an auto. 6L80e I believe and no stall but the tuner has done a lot of them and has one in his missus car.
  7. SS Flo Rida
    Gold Coast
  8. SS Flo Rida
    Gold Coast
    I like the vcm11 but the 12 I don't think will suit my purpose as well and I thought maybe the 227 inlet duration at 50 would push on the auto a bit
  9. OzTurtle
    OzTurtle Active Member
    Seaford; VIC
    VF II Redline
    I'm looking at doing the same around july, also an auto and leaving the stall stock but lowering diff to 3.70 (same as the manual). Tossing up between the VCM532 (215° 223° .583" .583" 112° LSA) or the Harrop H05 (216/224 .593" .592" 116 LSA).
  10. VESSVBLACK
    VESSVBLACK Active Member
    WA
    VE SS Series 1
    I wouldn't mind a recommendation, running the vcm 7 in ve ss, too big
  11. SS Flo Rida
    Gold Coast
    Cool! Will be interesting to see how it turns out when you select one. The 112 lsa should lump a lot more at idle I'd suspect the 116 lsa will be pretty stealth is it?
  12. OzTurtle
    Seaford; VIC
    VF II Redline
    Going from various recommendations, the 116 is a lot quieter, both the ones I mentioned were suggested because of the stock stall, and to prevent low speed surge with a more aggressive lobe. With lowering the diff I'm also thinking a bit meaner with the Harrop H02 (224'232 .609 . 610 114 LSA). And a trans tune with the remap, along with trans cooler.
  13. SS Flo Rida
    Gold Coast
    H02 with trans tune for sure. I'm getting mine done in a couple of weeks too but I've been told the trans cooler isn't effective so I'm fitting a Cadillac trans pan and deeper pickup and the trans tune. Also the under drive balancer was highly recommended by the shop doing the work and Walkinshaw up here when they quoted the cam upgrade. Apparently helps with auto's down low if your cam selection is aggressive for a stock stall.
  14. arronm
    arronm Active Member
    FPV F6 VF Redline WGN
    Trans cooler is effective. I have monitored temps. The temps lower considerably
  15. OzTurtle
    Seaford; VIC
    VF II Redline
    Definately go the trans cooler, and I've seen good reviews of the deep pan, just concerned with already suspect clearance issues after fitting the Pedders SportsRyder springs. I'll look further into the under drive balancer, anything to help the transmission low down.
  16. SS Flo Rida
    Gold Coast
    Does the cooler improve shift issues or is it more to prolong life span?
  17. SS Flo Rida
    Gold Coast
    The clearance with the caddy pan is really good it's not the really deep type intended for GM trucks it's not much deeper than the stock pan but it's got baffles around the pick up and the guru at sureshift automatics up here swears by them.
  18. arronm
    Lowered oil temps so better for life. I bought a VE kit and modified it.
    My VF box is tuned. Made a huge difference to shift speeds and firmness
  19. OzTurtle
    Seaford; VIC
    VF II Redline
    Looks like my shopping list is growing :idea:
  20. arronm
