Has any1 seen this sort of damage before?? Piston damage, bent pushrods, melted intake manifold
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Kraziiii, Jul 29, 2019.
  1. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
    20190728_230846_resize_87.jpg 20190728_230846_resize_87.jpg So I went against my own golden rule & I let 'a mate' who said they knew what they were doing, work on my pride & joy BIGGEST mistake I ever made as you can see...
    Luckily I have a really good mate who actually is a good mate & is saving my butt right now. We've decided to go with a motor swap but Im still trying to get my head around how the hell this much damage happened so quickly & what exactly has happened besides the obvious valves smacking the **** out of the pistons we haven't gone any further than ripping the heads off so far but I know the damage can't have stopped here
    Before anyone says 'never let a backyard mechanic play with your pride & joy' I stuck by that rule for the 5yrs I owned this car & learnt the hard way why I will never do it again. The lifesaver 'heaven sent' mechanic working on it now is fully qualified & knows his VE's.
    As much as he hates fixing ammatteur 'know it all' stuff ups, he's still helping me out & going over her with a fine tooth comb to make sure everything is back up to scratch & that nothing like this ever happens again...
    Any comments & insight will be greatly appreciated...
    Thanks in advance
  2. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    What did you have him do?
    Looks like oil buildup on the intake, if the runners had melted I'd wager a lot of the other plastic that makes contact with the head around the ports would have too.
    Looks like a ring land has broken off (or something was dropped in the cylinder) and smashed around inside the cylinder clogging up the valves and causing the pushrods to bend, doesn't look like the valves have made contact with the piston (no valve shaped indentations and no bent lips on the valves). Outside of awful tuning or dropping something down there, there's not a lot you could do to directly cause this.
  3. the_boozer
    the_boozer no more VK
    morwell
    Prado
    What was your mate doing to the engine in the first place? Was the pot with the broken piston full of coolant and something had to give ? Pissed n broke
  4. EYY
    EYY Well-Known Member
    VS Statesman
    Cammed it with stock pushrods (and possibly stock springs) and a **** tune?
    Intake valves stuck open caused the intake damage I’d guess?
    Tbh it’s going to be cheaper for you to find another good used engine. $3-4K would have you sorted. Still cheaper than spending money on that mess and you’ll save time too.
    Kraziiii likes this.
  5. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    Might help if you actually tell us full story...
    What work & mods did you get him to do?
    Did it do that straight after he finished job?
    Mileage & service history?
    Cam/dod lifters shat itself?
    Could easily say shoddy service history with engine having blowby issue or something hence oil crud filled manifold or dod lifter let go we don't know actual story/history...
  6. pnlimo
    pnlimo Member
    Northern Beaches Sydney NSW
    WM Caprice
    View attachment 206123 View attachment 206125 Yep. I've seen something similar a couple of years back. My L98 with 512,000 blew a piston and bent a con rod. Happened while starting. cranked a couple of times then, an almighty bang! Even with the high kms (car was serviced meticulously every 7,500 kms using fully synthetic oil and genuine GM filter) the engine was running perfectly before this happened. Fortunately, I sourced a low Km replacement motor which my mechanic fitted.
  7. immortality
    immortality Home of the smoky breakfast Bacon! Staff Member
    Sth Auck, NZ
    Fucked up cam timing causing things to hit and fire to go where it shouldn't = bent/broken and melted ****.
    losh1971 and VS_Pete like this.
  8. vywgn
    vywgn Active Member
    1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
    As above timing on the engine jumped around and caused the valves to touch
  9. Smitty
    Smitty Well-Known Member
    Bayside Melbourne
    Gen-F R8 Tourer wagon, VK Clubbie race car
    ... seen worse
    6800 WOT in third around the back of the Hayshed at PI
  10. Dylan kingswood
    Dylan kingswood Active Member
    Hobart
    2011 s2 Ve ss
    Valves haven’t touched that piston and valves are intact I’d say something foreign has gone through ? A ten mm but will do that sort of damage and that’s speaking from experience lol
    Tree cutter and losh1971 like this.
  11. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    Pissed n Broke Literally,
    By the looks of it, with the pure blonde stubby in the back ground :D
    losh1971 likes this.
  12. EYY
    VS Statesman
    Just noticed tie bar lifters. Old mate has definitely had a crack at camming that engine imo. Bet it's something with big lift and either haven't set up valvetrain or used correct components.
    Wonder whether it was on the limiter when it failed...
  13. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    Going by that bent pushrod, hmmmm?
  14. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
    Thanks for all the feedback guys. Sorry for the late reply.
    Before 'my mate' touched my car, I had already had a VCM 5 cam installed about 4yrs prior with Tie Morel Bar Lifters, Trend Pushrods, Pistons were flycut at the time aswell. Also had a set of Pacemaker Tri Y extractors fitted & custom '4 into 2' 2.5inch/3inch exhaust then Dyno Tuned at which she was pulling 320rkw by that stage. The place that did the engine work didnt think it needed double coil valve springs obviously & eventually one snapped.
    When this happened, my mate jumped in said he was going to rip the worked heads off his VE SSV & put them on mine. He pushed & pushed & eventually, I agreed.
    He swore black & blue he knew what he was doing & told me that I had no need to worry when I raised any issues that were bothering me.
    When we first kicked it over, he was standing right in front of the throttle body & it backfired loud af & literally blew the sunglasses he had on, straight off his head.
    I said wtf and again he said it was nothing to worry about.
    I had a sick feeling in my gut by then & knew I'd made a big mistake.
    When he told me to kick it over again a cpl of days later when we met back at the car, it started but was misfiring & sounded rough af. Thats when I started to tell him to leave it alone. He kept pushing & I had to literally move the commy from there so he would get his f'ing hands off it. I drove it to the closest safe place possible & even though it was a short distance, it obviously did a lot of damage
  15. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
  16. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
    And noo...its Definately not oil build up in the intake manifold. Its literally melted, hard as a rock. I tried to chip a piece out with a chisel & hammer & didnt get anywhere. Its shocking. I'll post some more pics for you tomorrow so you can have a better look & see what I mean
  17. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
    He was just supposed to be swapping the heads over to some worked newer ones that he had...
  18. Kraziiii
    Kraziiii New Member
    VE SSV 6.0
    When he told me to kick it over again a cpl of days later when we met back at the car, it started but was misfiring & sounded rough af. Thats when I started to tell him to leave it alone. He kept pushing & I had to literally move the commy from there so he would get his f'ing hands off it. I drove it to the closest safe place possible & even though it was a short distance, it obviously did a lot of damage.
    Its not oil build up in the manifold. The manifold was clean as a whistle before start up as it was cleaned when we took the old heads off.
    Its melted plastic inside.
    I'll post more pics tomorrow for you to have a better look
  19. VT2Commie
    VT2Commie Active Member
    WA
    VT2 Clubsport R8
    I'd be checking the engine number on the block is still the same as your rego papers TBH ?!?
  20. EYY
    VS Statesman
    Those don’t look like hardened pushrods to me... bet old mate kept the trend rods for himself
    Still gonna say pushrods were a big part of the problem.
    lmoengnr likes this.
