Handbrake Issue
Discussion in 'General Discussion' started by Catie95, Jul 9, 2019.
  1. Catie95
    Catie95 New Member
    Tas
    VX SS
    Hey guys after a bit of advice I have a 2002 vx ss and I notice the handbrake not holding as well as it used to this started a month or so ago and now when I put it on sometimes it holds as it should and other times you can feel the car move slightly as if it hasn't done it's job properly, when I take the handbrake off it feels really loose and has a longer distance I need to pull it up before it engages and wants to hold, sometimes the car won't move it's like the handbrake is stuck on and other times I'll take the hand brake off and you can feel the clunk in the car where the handbrake let's go. I took off tonight and my car didn't want to move and it felt like the handbrake was holding the car back, when I took my foot off the accelerator the car would slow right down like I was braking then I went onto the highway and it was driving along fine then twice in a 5 minute trip at 80kms my whole car went funny and started shaking in the backend for probably 10 seconds each time then it would stop, I thought it was my gears slipping but I stopped when I got onto main road and tested them all and they went in fine and smoothly. Would a handbrake adjustment and new pads fix this or is it something more?
  2. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    Sounds very much like a job for your local mechanic.
  3. Catie95
    Catie95 New Member
    Tas
    VX SS
    That's not helpful but thanks
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    There is a common problem with the VX and the handbrake. Try a Google search if you haven't because it has come up a bit. I think Holden brought out a fix for this, don't know if it comes under recall or not.
