Ghost in Machine
Discussion in 'Electrical Wiring / Questions' started by snipnrun, Dec 13, 2019.
  1. snipnrun
    snipnrun New Member
    Invercargill NZ
    2013 VE SV 6 SIDi Z Series 11
    Hi there, My 2013 SV6 Z series 11 SID i Sedan initially wouldn’t start, though it was the Bluetooth radio draining it as it would keep connected to my phone when I was in my house but now the camera & radio will go out for up to 3 days then ok again, now after trying to start it, I will release the key after 2 clicking fails & it continues & will start by itself ? Also the rear window button is playing up if that helps? I’m in Invercargill NZ so need any advice please, cheers.
  2. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Step one is to get the car scanned for codes. Body codes won't always set a Diagnostic Trouble Code warning light. High end diagnostic equipment will see the body and communication codes that cheaper blue tooth app based readers won't.
    Your car seems to be keeping the headunit on rather switching it off after the specified time frame. High end diagnostic equipment can possibly do some resets or recalibration and software updates to the car.
    The rear window switch will be a separate issue requiring a replacement switch. That's an easy job.
    krusing likes this.
