Gearbox pan bolts
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Makalaza, Apr 27, 2019.
  1. Makalaza
    Makalaza Member
    Waterford West Qld
    1994 VR Commodore Ute S1 / VX Executive Sedan S2
    Hi everyone - how tight do you do up the gearbox pan bolts without a torque wrench ? Went underneath to check leak out and found out half of my bolts were loose, I could do them up with my fingers.
    thanks everyone
  2. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Nip them up until they are just tight.
  3. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    Too loose and the bolts will loosen and fall out. Too tight and you may deform the pan lip and compromise the gasket.
    So get a torque wrench, they are not expensive. Then you can do them up to the recommended NM specified by Holden. That way you’ll avoid any issues.
  4. vs-lover
    vs-lover Well-Known Member
    VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
    I've always only used a quarter drive socket and nipped them up firmly, not real tight as the cork gasket will split and then it'll be start from the beginning again with all new stuff.
    But I totally agree with "skylarking" if you are going to do it by the book.
  5. Makalaza
    Makalaza Member
    Waterford West Qld
    Cheers guys
  6. EYY
    EYY Well-Known Member
    VS Statesman
    I did them for years without a torque wrench. Over a period of 12+ months they'd start to weep a little. Purchased a $30 1.4" tension wrench and haven't had any leaking at all from them for a very long time. Transmission pans are incredibly sensitive to small changes in tension settings.
    Too much and you'll crush the gasket and it'll lose elasticity and the bolts will become loose, too little and there's not enough pressure on the gasket and the bolts will come loose.
    I purchased a car a couple of years ago really cheap because it was leaking really badly from the transmission to the point it wouldn't drive properly. That trans ended up in my daily and it's been perfect ever since lol
  7. Makalaza
    Makalaza Member
    Waterford West Qld
    Thanks mate - i have ordered 1 off ebay
  8. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Hope you got the right one...the cheap (under 200$) one's they are only good for the middle of their range, so if its a 10 nm to 100nm it will only be good/accurate for around 30 to 60nm ...As I buy cheap :) I have 3 torque wrenches ... light range, middle and heavy duty..
